bezier tool
All  1  2-3
396.2 In reply to 396.1
Hi Juan, you can convert lines into smooth curves in MoI by using a combination of Add pt and Delete.
Here's an example - here is a polyline that I drew with Draw curve / Lines / Polyline - I selected it and used Edit / Show pts to make its points visible:
Next I have used Edit / Add pt to insert new points nearby the original ones. New points will be a "smooth" type of point unless you check the "Make corner point" box or hold down the control key. In this case I added them as smooth points:
The last step is to delete the old corner points from the end of the old line segments - these are shown selected in the step above. After deleting those corner points you will be left with a smooth curve:
So that's how to adjust an object to convert sharp "corner" points into smooth points - you insert new smooth points and delete any old sharp points. This is a little different than bezier style, but the end result is similar.
396.3
If you want a curve to have similar "smoothed" corners, you can also use 'fillet'.
In pic 1 (corner.jpg) i just made a line
In pic 2 (smooth.jpg) i used fillet on it with a radius of 2.
You can also continue afterwards with the tips Michael gave you.
(just delete some points).
Kind regards,
Edwin
EDITED: 15 Oct 2007 by EDWINTSI
Show messages: All  1  2-3
