bezier tool
396.1
Hi MIchael:
MOI can create lines and to convert them in curved as similar bezier to Corel
Best regards
Juan Galvan
396.2 In reply to 396.1
Hi Juan, you can convert lines into smooth curves in MoI by using a combination of Add pt and Delete.
Here's an example - here is a polyline that I drew with Draw curve / Lines / Polyline - I selected it and used Edit / Show pts to make its points visible:
Next I have used Edit / Add pt to insert new points nearby the original ones. New points will be a "smooth" type of point unless you check the "Make corner point" box or hold down the control key. In this case I added them as smooth points:
The last step is to delete the old corner points from the end of the old line segments - these are shown selected in the step above. After deleting those corner points you will be left with a smooth curve:
So that's how to adjust an object to convert sharp "corner" points into smooth points - you insert new smooth points and delete any old sharp points. This is a little different than bezier style, but the end result is similar.
396.3
If you want a curve to have similar "smoothed" corners, you can also use 'fillet'.
In pic 1 (corner.jpg) i just made a line
In pic 2 (smooth.jpg) i used fillet on it with a radius of 2.
You can also continue afterwards with the tips Michael gave you.
(just delete some points).
Kind regards,
Edwin
EDITED: 15 Oct 2007 by EDWINTSI
