Script Error - Line 107, Column 1:
All  1-7  8-11
3955.8 In reply to 3955.7
Interesting... I had brought up to Michael on an old Box I had where it would generate a jscript error for any command I ran from the command line...(Type Tab and command name). It would produce the error and then if I chose cancel, it would continue and perform normally. (So just a nuisance).
I had thought that I tracked it to loading Visual Studio 2010 beta and it's help system which was buggard up.. I ALSO had installed Notepad++ on that machine...
I am on a system right now with neither, and dont have the issue... Dont really need Notepad++, but will respond if the next time I load Visual Srtudio on THIS machine, the thing returns!!!
FYI.
3955.9 In reply to 3955.7
Hi Satoribomb, I'm glad you got everything working again.
Part of the work that I've been doing to move MoI v3 off of mshtml.dll also involves moving over to WebKit's JavaScript engine instead of the Windows jscript.dll . That will make MoI more self contained and more resilient to mild system or registry corruption.
3955.10 In reply to 3955.7
Hi Satoribomb,
> some of the JScript components of Win 7 got corrputed
Can you tell how to repair your Jscript ?
3955.11 In reply to 3955.10
Hi Anis,
My HP Tablet PC (Win 7 Pro) booted into self-repair mode after I was looking at boot repair options. I'm not sure how it happened, but it looks like HP's extensive suite of Bloatware worked to save the day. Go figure!
Show messages: All  1-7  8-11
