how to blend between two curves ?
All  1-2  3
395.3 In reply to 395.1
You can extrude existing curves (Construct/Extrude) a bit and make a blend surface between this two surfaces
with G1 or G2 continuity (Construct/Blend). Then you just extract the edge of blend
surface (Select edge, Edit/Copy, Edit/Paste -- or Ctrl+drag it) and delete unnecessary stuff...
Petr
Show messages: All  1-2  3
