no fillet
All  1-2  3-5
3949.3 In reply to 3949.1
Hi FiL & Burr - Burr I think you're right about that area giving the fillet some difficulty - that probably is just slightly too much of a crease there. If the pieces met smoothly at that point it would probably be easier to fillet.
But it looks like you can actually select the whole model without scaling it and then do a 2mm fillet - it will then do a fillet in that area that you indicated, and that seems to help making a better corner area for where the fillets on the outer edges come together as well.
So does that work for you FiL to get fillets on those other small areas as well? It looks like it may be difficult to get this filleted without doing those as well.
Thanks Burr for figuring it out!
3949.4 In reply to 3949.3
"But it looks like you can actually select the whole model without scaling it and then do a 2mm fillet -"""""""""""""
Ah yes it does.. I thought I tried that :o
Thanks for allowing me to continue to participate in the best forum on the web!
3949.5
Yes, it can be a solution... I guess we don't see it when the object'll be in alluminium and titanium.
The last mistery of 2010!
So do I!
Thank's very much Burr and Michael!
Two hours at the end of the year... good night and good 2011!
FiL
_________________________
That's a brilliant day to design!
Show messages: All  1-2  3-5
