MoI To Modo 501 - Contour rendering
 1  2-21  22-41  42-46
3926.2
This is great news!! Contours look great!
I've been playing with the new feature in 501 and by blending
AO and contour output you can get some nice sketch effects.
3926.3
Thanks for this upgraded exporter - it is something that I will find a use for when available.
3926.4 In reply to 3926.3
Hi rampackwobble, I've attached the patch here so you can give it a try.
To apply the patch download the attached lwo_contour_export_patch.zip file, and unzip it and copy the 3 included files into the MoI 2.0 installation folder. Then make sure MoI is not currently running, and then run the update.cmd file.
(NOTE: if you're on Windows 7 or Vista, the UAC system prevents the update.cmd file from writing to the "Program Files" folder, so either temporarily disable UAC or open up an admin command shell as described here and then run update.cmd from that command shell)
Then to activate the new LWO export option you need to enable it in moi.ini - to do that open up the moi.ini file for editing, there is a button for that in MoI under Options > General > "Edit .ini file".
Inside the .ini file, go to the [LWO] section and add in this entry:
[LWO]
WritePartTags=y
You can just add that as a new line at the end of the [LWO] section.
That will then make "Part" tags exported to the LWO file, with the polygons generated from each surface in the original NURBS model assigned to a different numbered Part tag. With those Part tags set up it is then possible to enable the contour rendering in Modo 501, so that a border will be rendered between the different surfaces in the original NURBS model.
Maybe PaQ can post some pointers about where those settings are at in Modo to enable the contour rendering inside there.
EDITED: 8 Jan 2011 by MICHAEL GIBSON
Nice modelisation & rendering!
3926.6
Fabulous! Nice work PaQ.
3926.7
Thanks for adding this Michael.
3926.8 In reply to 3926.1
I can see 501 has some serious high end anime potential.
@ paQ - I've always found your ships inspiring. That style really suits them too. Awesome.
@danperk - Very nice. You almost have a mecha thing going. For some reason I'm reminded of Ghost In The Shell (if you're familiar with that). The first movie. Definitely a great render.
3926.9
Michael, this quick response to your users just got you a sale.
I have had my eye on moi for a while now, but now that I have 501 and I saw this cool new feature you added it just tipped me over the edge.
I am really excited about learning nurbs, and from what I've seen moi looks ideal.
3926.10 In reply to 3926.4
Wow! PaQ, that is awesome.
Thanks Michael!
3926.11
Hello there,
Thanks everone
So to render the contour in modo :
- Turn the mesh into a static mesh ('change type in the item list')
- In the Shader tree, Final Color output ... activate the contours and use the segment boundaries method
That's it !
Pay attention, converting a mesh into a static mesh discard the uv's, so you might loose some of your shading work.
3926.12
Very nice models and great renders. I like your style a lot.
Don
3926.13
Ah this is brilliant. Thankyou so much!
Andy
3926.14
Ditto. Great looking renders. Thanks for the patch. I have modo 501 so have installed the patch.
Nigel / 3DKiwi
Homepages: 3dkiwi.co.nz & C4D Cafe
3926.15
Wow! Really cool models and rendering!
3926.16 In reply to 3926.15
Another bit of information for those wanting to render the countours in Lightwave. In modeler there is a parts to surface command. If you run this on the model, you can then turn on surface borders in Layout and it will render nice edges along those borders.
3926.17 In reply to 3926.16
They look like "MoI' renders after a little ground shadow and reflection additions... !!!! :o
3926.18
Just had to try it myself. :) Certainly better then the previous workflow I had for rendering curves in Modo.
3926.19 In reply to 3926.18
Looks great Andy!
Did you also generate the image at a larger initial size and then downscale it?
3926.20 In reply to 3926.19
No I didn't, this was the actual size of the render. I did increase the edge width from 1 px to 2px, and I wonder if that helps smooth out the antialiasing on the lines.
3926.21
Very cool stuff in this thread, well done guys.
Show messages:  1  2-21  22-41  42-46
