move problem
All  1  2-4
39.2 In reply to 39.1
Hi Kevin,
#1 - You can't really move a face around in MoI in the way that you do in a polygon modeling program. MoI objects just don't squish around like polygon models. You can move the face by selecting it and using "Separate", which will detach it from the solid object, then you can drag it around. But this is probably not what you want, because the other parts of the object won't pull around with it.
In MoI, instead of pulling faces around to alter a shape, you instead draw curves and construct surfaces from them that have the types of shapes that you want.
It might help me to understand what you're talking about if you could post a sample model or screenshot that shows what you're trying to do.
#2 - I'm sorry, I don't understand this one, could you explain it some more?
#3 - Use this:
[Shortcut Keys]
Ctrl+1=script:moi.ui.mainWindow.viewpanel.mode = 'Split';
Ctrl+2=script:moi.ui.mainWindow.viewpanel.mode = '3D';
Ctrl+3=script:moi.ui.mainWindow.viewpanel.mode = 'Top';
Ctrl+4=script:moi.ui.mainWindow.viewpanel.mode = 'Front';
Ctrl+5=script:moi.ui.mainWindow.viewpanel.mode = 'Right';
It looks like using Alt is broken right now, you'll have to use control instead. I'll try to fix using Alt for the next beta.
39.3 In reply to 39.2
Hi Michael
thank you for you quick reply. I knew the nurbs modeler that different with polygon modeler. It's my first use nurbs program,Moi,so i feel so interesting,It is potential program.i like it.
and I have one problem at this time,save or export obj.file possible? :-)
39.4 In reply to 39.3
I do plan on adding .obj export support, but it will probably be a little while before it gets in, maybe one or two months or so?
Sorry, I know this is a problem with trying to use the beta right now.
Show messages: All  1  2-4
