Moi3D to rapid protoype parts
 1-8  9-28
3897.9 In reply to 3897.6
Also when you export to STL you may want to use the "Divide larger than" option in the export dialog to break down any larger polygons into a bit more regularly sized diced up pieces.
Here's an example of that type of thing:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2833.5
You don't want to go too overboard with this because if you dice it up too finely it will create an enormous file size. But if you have some polygons that are spanning a large percentage distance of the model (like on a broad flat surface portion) it can be good to get them diced up into somewhat smaller fragments.
3897.10 In reply to 3897.8
****If that reads "Joined Srf" instead of "Solid" there, then that means your object is not fully closed.*****
Hello Michael,
that's a useful Info – Is there a way to recreate Solid from Surfaces for STL creation?
I guess, the fixing, I did afterwards in Netfabb wouldn't have been necessary if it was a solid. There were some "degenerated faces" -as they call it in NF- detected and I don't get where they came from, since it is a simple extrude – But no warnings, it wouldn't be printable: Neither in the software, nor from shapeways, so I guess It'll turn out alright.
Regards,
Sebastian
3897.11 In reply to 3897.10
Hi Sebastian,
Yes - the Edit > Join command will do this.
If you have individual surfaces that are touching each other along common edges, you can use the Join command to glue them together. And if you have all edges in your model joined to another edge, that makes it into a solid.
In order to be joined surfaces have to have edges that are close to one another though - within 0.005 units apart. So you need to do things like construct surfaces from some common curve structure, if you just kind of eyeball things and draw 2 different curves to use as guides for creating the surfaces they may not be close enough to each other.
If you are working on individual surfaces, you'll probably want to try to join things up more on the earlier side as you work on it and not do something like only create a bunch of surfaces and only join them together at the end, it's kind of too easy to miss a piece that way.
But if possible more of workflow where you work with a solid and then carve off pieces off it keeping it more a solid the whole time tends to be better. You can still work with surfaces in this kind of workflow as well, just use Edit > Separate to break off surfaces for some temporary work, and then use Edit > Join to glue them back into a solid again before going to a different step.
3897.12 In reply to 3897.11
+++If you have individual surfaces that are touching each other along common edges, you can use the Join command to glue them together. And if you have all edges in your model joined to another edge, that makes it into a solid.+++
Aah, alright, I get it. So there's no special command, but joining all the sufaces will do that.
I just had a look into my file, and it was already a solid. So this "degeneratd face" thingy probably was just something to omit or I picked some mesh settings that were too coarse.
thanks!
Sebastian
3897.13 In reply to 3897.12
Hi Sebastian,
Yup!
Yeah, you don't want to go too overboard with making a hugely dense mesh - but at the same time you don't want to be too stingy with too rough of one either.
When you save to a mesh format, there is a readout of the polygon count in the upper right area of the main window, here:
You only really need to get concerned about being too large in file size once that goes up over something like 100,000 faces.
On the other hand, you actually don't want to generate polygons that are extremely teeny tiny in size because the receiving application may decide to do stuff like fuse together vertices that are quite close to one another.
3897.14 In reply to 3897.12
There's also another STL viewer/inspector program here that you can use to load in and check the STL file:
http://www.materialise.com/MiniMagics
3897.15 In reply to 3897.14
Remember that Shapeways Servers love Millimeters! I can get a failed model with inches, then only reset to mm and the model is accepted... I have read on their site that the Shapeways printers work nativley in Meters, so keeping it Metric will help.
3897.16
Very good tips, thanks!
3897.17 In reply to 3897.5
The white piece is an ABS type of plastic. The grey is the same, but infused with aluminum powder.
HTH
Chris
3897.18 In reply to 3897.5
Less than 10 days from sending the file to receiving my parts. Shapeways is located in THE NETHERLANDS! Better service than a shop down the road.
$10 per piece.
3897.19 In reply to 3897.6
Not much. output as STL with a decent amount of polygons. Just don't go over 100k, or it will give their machine fits. LOL
3897.20 In reply to 3897.18
> $10 per piece.
That's another thing that is amazing about this, that it has become so very inexpensive.
3897.21 In reply to 3897.20
>> $10 per piece.
>- Michael
Michael, the cost of the 3D print machine is such that I am seriously considering the purchase of one. They are now in the $6-10k range depending on the features and detail resolution.
They used to be $100k when they first came out.
Cheers,
Chris
3897.22 In reply to 3897.21
Yeah but at $10 per part from the service you're going to have to make quite a lot of parts before it would be worthwhile monetarily to purchase the whole machine. But a faster turnaround time would definitely be a major benefit.
Maybe what will end up happening is that there will be more local shops that will have a machine so that you just send the model to your local shop and pick it up right away.
3897.23
You could try a RepRap machine.
http://reprap.org/wiki/Main_Page
Obviously, you have to be a bit of a do it yourself guy, but to me, none of it looks hard.
3897.24 In reply to 3897.22
Nice prints!
It's changing in the 3d printing area..
Stl printers for under 1300$, don't know of the output quality though...
http://www.bitsfrombytes.com/content/rapman
It seems to print around 8x8x10 inches
They are selling materials around 37-70$ a kilo
There's also kits like makerbot and reprap as Steve mentioned.
Marc
3897.25 In reply to 3897.24
> Any pointers on making a MoI file for Shapeway?
Michael,
Another thing you'll want to do is keep your model in positive xyz space. Most machines don't like STL to be in the minus direction of any axis.
I certainly can't afford a 3D printer, but I do play around with a CNC router. Many of the same things apply!
Mike...
3897.26 In reply to 3897.18
That $10 isn`t much. I think they print a lot`s of part so they can dump prises so low :)
What is the volume of your part you printed out?
d3
3897.27 In reply to 3897.23
Incredibly LOW resolution. More of a toy for tinkerers than a useful tool at this point. Maybe someday. Prices keep dropping. I fully expect to see state of the art on your desktop for under $5k within 2 years.
C.
3897.28
The RepRap can go to quite fine resolutions but is slow. The problem with printed parts is overhangs. Shapeways quote a minimum feature size of 2mm which is worse than the RepRap.
I think to get really high resolution with overhangs, unsupported melted plastic is not the way to go. Better is the layered powder with sprayed binder method.
EDITED: 9 Dec 2010 by STEVEH
Show messages:  1-8  9-28
