MoI finds a home
 1-14  15-34  35-54  55-70
3892.55 In reply to 3892.54
Hi Michael T,
> Is there a setting I am missing?
Not that I know of, I think what you are trying is supposed to work.
Could you please post a simple example model like a box in both STEP and SAT formats that has this problem so I can take a look at what is happening when it is opened in MoI?
Also are you using the File / Open command to bring it into MoI or the File / Import command?
The difference between those 2 commands is that "opening" a file brings in all the settings from the file as well such as its unit settings. If you do an "import" of a file into MoI on the other hand, that merges the file with the current model instead of just replacing the current model.
3892.56
Hi Michael T,
Please try this settings. :)
EDITED: 15 Dec 2010 by RALF-S
Size: 82 KB, Downloaded: 34 times, Dimensions: 909x897px
3892.57 In reply to 3892.55
Hi Michael G.
I am attaching a zip file that contains both STEP and SAT files. I did try Import and Open. The results were the same.
Michael T.
3892.58 In reply to 3892.56
Hi Ralf-S,
I do have set to that.
Michael T.
3892.59 In reply to 3892.57
Hi Michael T - the problem seems to be that the files written from Alibre are stored as centimeter units in the file. Maybe there is some export option in Alibre that controls what units are used to export the file separate from the units currently used in modeling?
When I open your SAT file in MoI, you can see that it is read in centimeters, the units are displayed in the coordinate controls in the bottom toolbar here:
So if you want to use millimeters as your units instead of centimeters, after loading the SAT file go to Options > General > Unit system, and change the Unit system option there to say "Unit system: Millimeters". You'll also want the checkbox for "Scale on unit system change" under the Unit options (the button right next to the units dropdown, the dialog that Ralf was showing above) to be enabled so that your model scales to the same proportions in mm when you switch the units. Also you'll probably want that second option "Scale when importing different units" to also be enabled, that will make the Import command scale imported geometry to maintain its physical unit size.
For the STEP format import, MoI did not seem to be able to read the units setting from the file at all in that case, I'll need to examine that to see why. So after reading in the STEP file the units in MoI are set to "No unit system". To fix this up you will need to set the units twice in a row - first change it from "No unit system" to centimeters. This will not scale the model but it will get your unit system to centimeters to match what was in the file. Then set the units a second time to mm and then the switch from cm to mm will scale your object up and you'll have what you need.
So for either case, you just need to go to the Unit system option in MoI and set it (twice for the STEP file first to cm and then to mm) and that should solve the problem. Please let me know if that does not solve the issue for you.
You may want to check in the Alibre export options though to see if there is some option that is set that is making it export files using centimeters as the units in the exported file.
3892.60 In reply to 3892.59
Thanks Michael G. I'll check it out and let you know.
Michael T.
3892.61 In reply to 3892.59
Hi Michael G.
I could not find any settings in Alibre for STEP export, but I imported the same Alibre AP 203 Step file into ViacAD, TurboCAD Pro and IronCAD's Inovate and they all came in correct to scale in millimeters.
The steps you showed me earlier work fine, but my concern is that if someone were to receive a STEP or SAT file from Alibre and open it in MoI without paying attention, they could be heading for disaster downstream. Normally I would be working in the reverse, bringing MoI data into Alibre, but I wanted reference geometry for a test when I discovered this.
I'll go ahead and try the other import/export file types between Alibre and MoI and let you know what I find out.
Michael T.
3892.62 In reply to 3892.61
Hi MichaelT - if I open up the STEP file in Rhino, I get units set to cm in there.
Also if you open up the STEP file in a text editor like notepad, you can actually scroll down and see that the units seem to be set to centimeters, this is the relevant part of the file:
#99=(
LENGTH_UNIT()
NAMED_UNIT(*)
SI_UNIT(.CENTI.,.METRE.)
There seems to be some problem in MoI's STEP importer that is not reading in that units setting properly though. I'll explore this some and find out if this can be fixed, it may be something that needs to be fixed by the author of the import libraries that MoI uses.
They seem to be converting from the centimeter units that are actually set in the file into mm.
I guess that those systems are working more like MoI's import command where the units setting retains its current setting when opening that file and instead the imported file is scaled to convert into the current unit system, rather than the current unit system actually getting set to what was in the file.
Actually the SAT file seems to be working fine as far as units go - when you open the file up in MoI you get the units set to cm with the part in the proper size in centimeters.
I also double checked the SAT file by directly loading it into notepad as well, and in its header it is marked as having the units in the file as cm as well - the setting for that is not as easy to see as the STEP file one, it comes from the 3rd line in the file which says:
10 9.9999999999999995e-007 1e-010
The 10 there at the front of that line means that each numeric unit in the file represents 10mm , or in other words the numbers stored in the file are stored as centimeters.
3892.63 In reply to 3892.61
Hi Michael T - I also did a couple of simple tests with some basic shapes like a box out of Alibre and into MoI using STEP format, and these tests seem to bring the unit setting (in cm) over into MoI ok.
So there seems to be some problem dealing with something in your specific model, it seems to be having some problem with the cylinder piece on it and I guess that may be causing an error during the import process which makes it not get to handle reading in the units setting as it is supposed to.
Could you also give a try with a simple shape like a box to verify that works ok?
I've sent your STEP file to the author of the import libraries that MoI uses to ask why the units are not read in for that particular case, he may be able to figure out what is going wrong.
You may also want to try IGES format for getting your model over.
3892.64
Hello, new member here.
Just to add to this thread.
I am a freelance design draughtsman and have been using Alibre as my parametric modelling software for around 4 years and think it is excellent. Having used Inventor & Solidworks extensively I prefer to use Alibre for various reasons.
My surface modelling experience is limited having only experienced it in ACAD. Anyway I would just like too say I am completely hooked on MOI (only had it for a few days since the Alibre offer) it is easy to learn, has a great looking and simple interface giving excellent results.
Every credit to you Michael.... Brilliant !!
Thank you.
Alexander
3892.65 In reply to 3892.63
Hi Michael G.,
I just had the same STEP file issue with a SolidWorks STEP file I downloaded from the web. I have attached it here. The same SAT file came in okay.
Just thought I would let you know.
Michael T.
3892.66 In reply to 3892.64
Hi Alexander, thanks very much - I'm glad that you like MoI!
3892.67 In reply to 3892.65
Hi Michael T,
Thanks for posting the file Michael T - this looks like another problem with reading the units setting from the file, but it is a different problem than the previous one.
I've heard back from the STEP library author for the previous problem and he has a fix coming for it in the next version of the library. I'll also send him this other one and see if that can also be fixed.
The problem with this new one seems to be that the library thinks the units in the file are supposed to be meters, when I guess they are actually in inches. This seems to be due to some kind of alternate method used for designating the units, it's got these entries in the STEP data:
#5130 =( CONVERSION_BASED_UNIT ( 'INCH', #5131 ) LENGTH_UNIT ( ) NAMED_UNIT ( #5132 ) );
#5133 =( LENGTH_UNIT ( ) NAMED_UNIT ( * ) SI_UNIT ( $, .METRE. ) );
The library seems to be not handling or taking into account that "Conversion based unit" stuff in the file.
In order to fix this second one into MoI, you'll need to turn off the option to scale objects when the unit system changes, then change the units from meters into inches, then turn the option to scale back on and then change the units to mm to get the correct final result in mm.
3892.68 In reply to 3892.67
Hi Michael G.
Yep, that does it.
I will still try some of the other file conversions between these various programs, and let you know my results.
Thanks again,
Michael T.
3892.69 In reply to 3892.68
Hi Michael T, so I found out what is going on with that second STEP file, the one from SolidWorks - it's actually a bug in MoI and not in the STEP import library itself.
It's possible for STEP files to store not only a unit system but also a scale factor that is supposed to be applied to the unit system as well, and MoI was not paying attention to this additional scale factor.
So for example that file you posted has 1 unit = 1 inch in size, but for whatever reason instead of it just directly saying that the units were inches, it instead was set to say that the units were meters with an additional scale factor of 0.0254 applied to it (which is 1 inch in meters). But MoI was only picking up on the meters setting part and not the additional 0.0254 scale factor part.
So I've added that to my list of stuff to fix in MoI. Thanks for posting the example file,
3892.70 In reply to 3892.69
No problem,
Always glad to try to help.
Michael T.
Show messages:  1-14  15-34  35-54  55-70
