Scene Management
All  1-5  6-7
3877.6 In reply to 3877.3
Hi Andy, here's a script that should perform the edge showing operation that you wanted:
script: /* Show all edges of visible objects */ var breps = moi.geometryDatabase.getObjects().getBReps(); for ( var i = 0; i < breps.length; ++i ) { var brep = breps.item(i); if ( !brep.hidden ) brep.getEdges().setProperty( 'hidden', false ); }
To set this up, go to Options> Shortcut keys, and push the Add button to add a new blank entry to the top of the list.
Then for the Key column, put in whatever key you want to trigger it, maybe E since it involves edges.
Then in the Command column on the right-hand side, paste in the above script.
Then after that you can type E (or whatever you set up as the key) to get the particular edges that you want to be shown - the script will only show edges on objects that are currently visible and not touch the edges on objects that are totally hidden.
3877.7 In reply to 3877.6
Thanks! I will give this a try as soon as I get a chance.
Andy
Show messages: All  1-5  6-7
