Hi Burr,
> I dont know Rhino well enough to pull out a command
> to get my dims as "geometry" or "explode" them to get
> them in a dwg file...
There is an Explode command in Rhino which will do that - just select your dims, and type Explode and push Enter.
That should convert the dimension entity into several polylines and a "text object" entity. You can then select the text object and run explode again on it if you want to convert it also into just plain curves.
