W: script for selecting perimeter of selected face
3867.1
Heya guys, I poked around for a bit and couldn't find other instances of this functionality.
What I would like to do is select a face of a solid, then select the lines that make its perimeter, like so:
3867.2 In reply to 3867.1
Hi Yenmonger, there is one script here that will allow you to select all the edges of one face boundary, the way it works is by selecting 2 edges of the boundary and then running the script:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3335.5
That allows you to be more selective since it would let you grab just the outside boundary of a face that has a bunch of internal holes in it for example.
To just switch selection to all edges that belong to a selected face, use this script:
script: /* switch selection from a face to its edges */ var gd = moi.geometryDatabase; var faces = gd.getSelectedObjects().getFaces(); gd.deselectAll(); for ( var i = 0; i < faces.length; ++i ) faces.item(i).getEdges().setProperty( 'selected', true );
3867.3 In reply to 3867.2
Does this a new Script not yet published?
3867.4 In reply to 3867.3
Hi Pilou, actually that script has come up a couple of times before:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2434.8
http://moi3d.com/forum/index.php?webtag=MOI&msg=2088.2
3867.5 In reply to 3867.2
Wooo! Sniff, I love you, man!
