Paneling Techniques.
All  1-4  5-6
3859.5 In reply to 3859.4
One more question along these same lines. Is there a way to inset a particular surface while not extruding it?
For example I have this surface.
I want to do an inset, similar to the image attached, but I don't want to extrude it inwards. Bascially I want an inset but with a 0 height. I tried the seperate height option, but entering 0 would cause the tool to not work.
3859.6 In reply to 3859.5
Hi Andy,
Inset will always try to make a protrusion inwards or outwards, but if you enable the "Grooved" option and leave the groove width to be empty or set groove width to 0, you will get the "plug" as a separate object which will be flush to the original shape.
Or depending on what you want you may actually want to put in a small value for the groove width so that there is a little bit of separation between the outer and inner pieces, like this:
Original surface:
Inset with "Grooved" option enabled, with a small groove width:
Show messages: All  1-4  5-6
