Problem solved!!! Subd -> nurbs
 1-12  13-25
3854.13 In reply to 3854.12
I can understand about the price problem.
As for the format, .fbx seems fine for this kind of transfer, seems to work pretty well to export modo sub-d weight to maya.
3854.14
OT BUT I think that is very interesting for Modo & MoI... users. Son Kim posted this @ the Modo Forum http://forums.luxology.com/discussion/topic.aspx?id=51113
[I got a email reply from the CTO Gary Crocker, it seems positive:
"Thanks for the forum post. We are in contact with the modo team about our technology. One option we will consider is a plug-in. Modo is probably the premiere sub-d platform. We are excited about the possibility of working with them.
Gary Crocker"
In another reply he writes:
"Tell me more about what you would like to see in a NURBS to Sub-D converter?
Gary"
This was a reply about my question of plugin for MOI to Modo.]
3854.15 In reply to 3854.14
I don't really have a whole lot of confidence that the reverse direction of starting with NURBS and going to Sub-d is very feasible in a robust dependable way.
It could be possible for some special cases like when you have untrimmed surfaces. But once you have done any trimming or boolean operations, that will put trim curves on the surfaces, which means that the control point structure of the underlying surface can no longer just be used directly to convert over to a sub-d mesh, instead a completely new set of quads have to be created that attempt to follow the trim curves of the NURBS surface.
Then even after that, Sub-d surfaces are quite sensitive to the topology of the control mesh - if there is any irregularity to the topology it will result in things like ripples and bumps in the sub-d surface.
There is a good overview here on the different kinds of artifacts that are caused by poor sub-d topology:
http://guerrillacg.org/home/3d-polygon-modeling/subdivision-topology-artifacts
It's very difficult to make a clean topology with a totally automatic method, particularly with CAD models that may have a mix of sharp edges and smooth pieces as well as a mixture of small and larger features within the same model.
Here's a simple example - here I have created an extruded NURBS surface and then trimmed some areas of it away.
How would you then expect for that surface with the holes in it to be converted into a sub-d mesh?
It's going to be very difficult for an automated tiling mechanism to produce a very nice topology on that, especially in areas where 2 trim curves come close to each other.
And as you can see in the video linked to above, defects in sub-d topology result in things like ripples and bumps in the sub-d surface itself, so a conversion that generates poor topology will tend to mutate the shape and potentially introduce defects in what was previously a totally smooth extruded NURBS surface.
If that kind of shape mutation doesn't bother you, then your project probably fits more naturally just being done with sub-d from the beginning rather than in NURBS.
3854.16 In reply to 3854.14
And beyond just getting ripples and bumps, applying sub-d smoothing just generally produces a sort of melting effect, which means that various aspects of your model's shape will be altered in a NURBS to Sub-d conversion attempt.
So that whole process of a NURBS to Sub-d conversion would be pretty weird - things like crisp accurate mechanical shapes (which is normally what you want to be using a NURBS modeler to produce) will become kind of melted saggy things potentially with ripples and bumps in areas that used to be perfectly smooth in the original NURBS model.
Certainly there could be uses for that kind of melting mutation, but it's kind of a weird and poorly fitting workflow since the advantages of NURBS modeling are that you can produce crisp and accurate stuff with it.
If you want melted non-mechanical stuff, you should most likely be creating that as a sub-d model from the start rather than trying to use a tool like NURBS modeling that has a completely different focus.
3854.17 In reply to 3854.14
But the other direction, Sub-d to NURBS, as mentioned originally in this thread is much more workable because it doesn't require a completely new topology to be magically created as is needed with trimmed NURBS to Sub-d.
3854.18 In reply to 3854.16
Thats a really good point Michael.
It's funny how many people don't understand the fundamental differences between nurbs and poly modeling.
For sculptural work with high detail, you are going to use polys if you want to be efficient and produce the best detail. And you can program a toolpath for a CNC machine from a polygonal model. Thats the advantage of SubDs ... you can make the polys small enough so that you will never see them in the machined piece.
I suppose you could model anything with nurbs, if you made the patches small enough, and you didn't care about the time.
Chris
3854.19 In reply to 3854.11
Yes, you are right, there are a lot of big improvements in Moi over Rhino and ofcourse a lot of things that Rhino can do that Moi can't.
But in general workflow and 'feel' than I see a lot of similarities, and that could be down to the fact it is designed by the same person:), I know I would like my products to reflect the 'feel' I am about, although with improvements:))
I love Moi & Rhino so I must really appreciate your work ;)
3854.20 In reply to 3854.19
Thanks Olio, I'm glad that you like Rhino too! :)
Rhino and MoI actually have fairly different focus areas - Rhino was fairly focused on making things comfortable to someone who had experience using AutoCAD, while MoI tries to be more friendly to people who may not have any prior CAD experience at all.
These different focus areas have a pretty broad effect on things, like since Rhino is focused on a more technical user it is more of a pattern in Rhino to have some thousands of commands for doing a ton of different things. But MoI with much more of a focus on ease of use tries not to have that kind of complexity in it and the UI design for MoI goes much more slowly and carefully than just adding in tons of stuff rapidly... Anyway, these different focuses do lead to differences in workflow as well.
3854.21 In reply to 3854.20
Yes, I personally find MoI much easier to work with than other programs. I have been doing fairly simple (though some have been complex) architectural modeling for about 25 years and MoI definitely speeds up my work flow. I rarely have to revert to other tools throughout the model building process. Love MoI and it gets better and better.
eric
3854.22 In reply to 3854.21
Just my thoughts on the Rhino vs Moi thing.
I bought Rhino while I was a student for a very good price (they let you use it commercially too which is very nice of them). I tried to learn it however and always ended up feeling frustrated, it was just too different from everything I learned up to that point.
Fast forward about 3 years and I start to realize most of my personal work (mechanical modeling, ships, cars, bikes, planes) is much better suited to nurbs than SubD modeling (I can make SubD's do what I want and need, but it is painful sometimes) so I dig out my copy of Rhino and give it a whirl. Same old frustrations. Fast forward another 6 months and I discover Moi and for the first time nurbs just kind of click. I'm totally hooked now. :)
3854.23 In reply to 3854.22
It's also funny how learning MoI kindof opens up "RHINO"!! Although, rhino needs time put in to figure out the plethora..
3854.24
True, I opened up Rhino yesterday just to see how my MOI model looked in Rhino. It definately clicked a bit more then it used to, but it's still just a massive program. I am sure if my needs ever outgrow MOI, I would be able to jump into Rhino relatively easily. I don't see that happening though as I'm not a car designer or industrial designer, or engineer, I'm an artist and I just want to get out the ideas that I have swimming in my head.
Andy
3854.25 In reply to 3854.24
Hi Andy,
Btw, in case you didnt know, you can just clipboard copy your models/curves (ctrl-C / ctrl-V ) between MoI and Rhino ;)
Show messages:  1-12  13-25
