relative & absolute angles
All  1-5  6-9
3840.6 In reply to 3840.5
Hi nos,
> Would it be possible to change this in the configuration somehow?
Sorry, no - the rotate command does not have any concept in it of knowing whether you are moving the mouse in a clockwise or counter-clockwise manner.
It is not even required for you to move the mouse around in rotate at all - you can just click an origin point and then type in a rotation angle.
> So using the rotation tool clockwise I have to calculate
> most of the time 360-<the angle I want to apply>.
Sorry, I'm not sure if I understand this part - do you mean you're calculating this just on the visual feedback information you get while you are moving the mouse around?
Because if you want to apply a specific clockwise angle you can do that just by entering it in with a negative sign in front of it, for example type in -90 to rotate clockwise by 90 degrees.
3840.7
> Like for example would you want the angle that currently shows as 270 degrees to instead show as -90 ?
yes exactly.
> Sorry, I'm not sure if I understand this part - do you mean you're calculating this just on the visual feedback information you get while you > are moving the mouse around?
Yes set the angle that it looks visually right and then change the angel to an even number. Sometimes if I apply an angel it isn't important if it's 32° or 34°. But I don't wont an angel which is 32.354° cause if I build this part it's unlike harder to assemble it.
~nos
3840.8 In reply to 3840.7
Hi nos - you can try the attached modified version of Rotate to see if that helps.
To apply the modified version, copy the attached Rotate.htm file over top of the original version inside of the \commands subfolder inside of MoI's main installation folder. You may want to make a copy of the original one first so you can easily restore it if needed.
The new version will give a negative number readout for angles between 180 and 360 degrees. So for example if you go to what would have previously been an angle that displayed 270 degrees, it will instead show -90 with this modified version.
It won't matter which direction you move the mouse in though, whether you move it clockwise to the 270 degree mark or counter-clockwise to that position it will read -90 in either case.
3840.9
That works great, thanks alot
~nos
Show messages: All  1-5  6-9
