Object grouping and organization.
 1-6  7-26  27-32
384.7 In reply to 384.6
> If there is any other opinion, I think it would be useful to have it here.
Yes, let me second this. If anyone has any ideas on what they'd like to see in this area, or recommendations on other programs that handle this area well, please post your thoughts here.
The more information that I have about this the better.
384.8 In reply to 384.7
Well there is plenty of room under the right hand side tool buttons. or above it.
Also, I wouldn't mind seeing the group window as a floating window that can be called up
via a button that would sit with the other tool buttons.
That way, it's gone unless you need it.
Mike Fitz
www.3dartz.com
384.9
Hey Michael,
You might take a look at Wings 3D & Adobe Illustrator for ways to organize the Grouping/Layering functions. Wings' "Geometry Graph" window allows you to select, name, view/hide, and change the shading options of individual objects. See the "Wings" image below. However, it is limited by not being able to handle re-ordering, hierarchies or "group operations" (like multi-selecting to change the shading or visibility of many objects at once). As well, each object has its own entry making objects composed of a lot of primitives- like the spider tank rough-out in my screen capture - take up a lot of space in the window.
Illustrator uses a similar approach but allows parenting, multi-select and group operations within and across layers - see Illustrator image below.
Both examples use a tabular layout, almost like a spreadsheet, which keeps navigation simple, direct and easy. Using this kind of layout would also allow you to move some of the commands (like "hide", "show points", etc) off of the edit panel, and onto this new panel. Like the rest of the GUI, the Geometry/Layer section could be added to the right hand side as a collapsible panel, perhaps as part of the middle edit/view panel. This approach would keep current the look and feel intact, adds to the functionality, provides ease of use and doesn't have to hog precious UI real-estate. A win for everyone, provided the coding isn't too back-breaking!
Hope this is helpful info. I know this functionality would benefit me greatly and improve MoI's already fast and comfortable workflow.
Thanks for soliciting and valuing our input.
384.10
I am terrified with what I see here... I fear that this is the most difficult decision for you Michael...
384.11
the wings and illlustrator windows scare me.... they almost look like command prompt windows and don't fit with the elegent
design look of MOI.
I say we leave the graphical look to Michael, but submit any sort of advantageous workflow....
2cents.... right there!
Mike Fitz
www.3dartz.com
384.12 In reply to 384.11
design look of MOI.
I agree 100%. What we should have (instead of a scene hierarchy tree) is an object and subobject hierarchy tree.
I have to say this again... Max's object grouping with MoI's ease of use, powerful commands and perfect UI will be a best seller. To be able to have this combination MoI should have a kind of modifiers and a very detailed editable modification history
My 2 cents :)
As Moi is used principaly without the keyboard insert Text of name of Object will be painful
So just use the "Palett color of windows" with 3 levels of depth for group "objects colored"
So you obtain
48 * 3 = 114 virtual "boxes" inside you can put any numbers of objects!
And you can select or unselect any "boxes" that you want !
so 48 *48 *48 = 110 592 combinaisons only by clicking color boxes ;)
Advantage : you will see all the arborescence hierachy in a wink ;)
Seems it's ilusion to list 100 000 or more objects by "text"
Just colored objects in a "box" seems sufficient :)
Colorisation of objects will be Enable/ Disable
@Michael : the little yellow line over blue object (or elsewhere) is my fault and not a default of the Moi system image :)
One more time : at first view I believed that we can only put "one "image" by "Window, Face, Top..." but there is not limit!!! :D
Transparency seems woks very well this time :)
EDITED: 21 Feb 2007 by PILOU
384.14 In reply to 384.13
PILOU wrote:
...As Moi is used principaly without the keyboard insert Text of name of Object will be painful
My opinion is:
The ability of using tablet PC with MoI cannot possibly change the fact that MoI is a CAD application using NURBS. There could never be a decent CAD application without text writing, editing and formatting capabilities. Also dimensions will probably need some editing too.
I understand what you mean PILOU but there is another way to minimize keyboard entry... Automatic naming for curves and predefined solids, for example circle1, circle2, box1, box2 etc...There will be a way for all others, I'm sure. After all, what is important is the ability to change and re-model the objects, not selecting them or naming them... Names are important when other things are involved, like bill of materials or quantity schedule for example.
Selecting the object [solid3245] you will be able to see [circle74] and the [rectang35]. Then by changing the diameter of [circle74] (two clicks or a simple slider) you have a new [solid3245]
Now, if for a reason you want to rename [solid3245] to [main connector] for example, it is up to you.
I can't think of a faster way of modeling and re-modeling an object.
384.15 In reply to 384.14
@ JTB : Agree with you if you not consider MoI as a speedy "Pre Modeler"
Depend of the finality of the conceptor :)
Sure if you can name each object that will be an ideal terrific thing!
EDITED: 12 Feb 2007 by PILOU
384.16 In reply to 384.15
@Pilou
I think you see MoI as it is right now, I am thinking of how it will be as a future version. I believe that Michael is not preparing a Pre-Modeler, and Rhino for example is not at all a pre-modeler...
I can understand your problem with too much use of text but the automatic naming can be a solution. After all, every program I know has some kind of object naming, so it will be easy to find a way on that.
BTW, the idea with the boxes was very original!
384.17 In reply to 384.13
I don't think that this is the way to go.
We run out of quickly identifiable colors very quickly.
As the number of the objects build up so will the similiar colored groups and
that will be confusing.
And besides it starts to look very "toy" like this way.
Mike Fitz
www.3dartz.com
384.18 In reply to 384.16
@JTB
< and Rhino for example is not at all a pre-modeler...
Of course yes!
But maybe you can see MoI as a pre Modeler for Rhino for example :)
@Fitz
< it starts to look very "toy" like this way
Of course I drew some colorful objects :)
Life is not also a sort of "Game of Life"? So...;)
Serious pieces can be colored too :)
EDITED: 13 Feb 2007 by PILOU
384.19 In reply to 384.13
Pilou:
Naming objects and groups of them though is a important part of organizing. If I'm modeling a castle, and want to hide everything but the north tower, having a name allows me to see this, and in a heirarchy tree, I can show it, and hide the others. I don't have to remember that the North tower is the green box 4 levels down.
Colors are cute, but it's easy to run out of them. In a complex scene, and the fact selecting currently changes the color of the item selected, how many objects till "Pumpkin" becomes indistinguishable from "Orange"? It can quickly become difficult to tell closely related colors apart, especially since silo has shading. So "Orange" in the shadow may look like brown.
Minimizing keyboard interaction is good, but I want labels.
I want my tank model to have a "Barrel" group, and a "Turret" group, and a "Tread" group. And I may want to assign a custom color. And I want my reference image, and starting curves assigned to a different layer so I can hide/show them as needed.
And trees of heirarchal boxes leads to box shuffling hell, as you move them up and around, and organize them. Anyone who has dealt with filesystems knows this.
384.20 In reply to 384.19
yeah, what he said:)
Maybe you right It was just my 2 cents:)
384.22 In reply to 384.21
sorry for my ignorance, but what all falls under the "pre-modeler" blanket?
with great interest, i have been looking at as much response to MoI as possible. something i do everyday is look to improve the tools i use, with great respect to what tasks they are best suited. i want to emphasize what has great appeal to myself as i use MoI: simplistic GUI with little or no need to touch the keyboard during the modeling process. i believe i have only pulled up to the keys to type a file name. if there was a popup keyboard on screen, i wouldn't even have to do that. just to clarify, i do a lot of 2d/3d cad design which i would gouge your eyes out if you made me work without a keyboard, but what MoI seems to be geared for is a less device dependant environment, where your primary interface is either stylus (appears to me as the goal) or mouse alone. I am still diving in to the overall response, but this is what i have found so far.
following with my conclusion the intent is for a stylus/minimalist interface approach, to better attain the "moment" without obstruction of names and extended hierarchy until after the "moment" has developed, i give thought to the PILOU'ian attempt to allow a method of quickly grouping/layering without an extensive compromise on order. no, i'm not sure what to suggest as a solution, i just now have begun the thought. i merely wanted to re-express the direction i understand to be the inceptual intent. PLEASE correct me if this is errant.
is MoI best suited for large assemblies and/or intensive mechanisms, or is it tooled for conceptual yet developable components, or the organic characteristic, or is it to be all and more? the application will drive the implementations. our purpose is to seed the process.
cheers.
384.23 In reply to 384.22
Well, if speed is the case,
why not an auto naming feature that is activated with the object selected and hitting a specific key stroke.
the software will automatically create a group of the selected object(s).
then if you want to, later you can call up a floating window that has the project object list/tree whatever.
Mike Fitz
www.3dartz.com
384.24 In reply to 384.22
Hi MadTooler, you've definitely got the inceptual intent down there.
Initially MoI was created to fill a gap that I perceived in the CAD market, where reliance on the keyboard, right and middle click and the scroll wheel caused existing CAD programs to be frustrating to use with only a tablet. As far as I could tell, there just did not exist any CAD software that worked well in this situation. So that provided an opportunity to do something a little different than anything else out there, which is good because I didn't really want to spend a lot of effort in just trying to make a clone of already existing stuff.
But during the development of a UI to fill that niche, I discovered that removing reliance on those elements also just greatly simplified the UI overall even with a mouse, since less stuff tends to be hidden and things are activated more with just simple left-clicks.
This increased general purpose ease of use, and a focus on fluid ease of use and quick results has kind of become the more dominant intent now. But it is not at odds with the use of the stylus, it encompasses that too.
As time goes on, it will be a goal to add additional power and capabilities to the design tools while still maintaining the fluidity and ease of use. This will happen kind of gradually and carefully in certain areas - object grouping and organization is one of these.
Right now the toolset is more suitable for somewhat less complex models, quick designs, kind of early stage conceptual work. As time goes on I expect for MoI to be more applicable to larger chunks of the design process, although still slanted more towards the earlier stages. This will be an ongoing and slow evolution though.
Does that give you some more of an overview of some of the design philosophy and history?
384.25
So how will this thing be solved....are we going to see usual layres in the next beta or something different...
384.26 In reply to 384.25
Hi Kreten, I don't expect to have anything in this area for V1, it is something that I want to tackle for V2.
The usual CAD layer system has some limitations that I don't like. Like for example since each object goes only on one layer, you can't very easily have organizations like having a car where one wheel is on a layer "wheels", but also the 2 front wheels are on a layer "front half of car", as one example.
I want to have something that isn't limited in that manner. Also I don't really want to have separate systems for both groups and layers, they are performing similar duties so from my view it is bad to have totally different systems for them.
But I haven't had time yet to design a system that accomplishes these things, it will be very time consuming to design a good system for this, so that's why it is not going to be ready for V1, I just don't want to delay V1 for this.
Show messages:  1-6  7-26  27-32
