Object grouping and organization.
 1  2-21  22-32
384.22 In reply to 384.21
sorry for my ignorance, but what all falls under the "pre-modeler" blanket?
with great interest, i have been looking at as much response to MoI as possible. something i do everyday is look to improve the tools i use, with great respect to what tasks they are best suited. i want to emphasize what has great appeal to myself as i use MoI: simplistic GUI with little or no need to touch the keyboard during the modeling process. i believe i have only pulled up to the keys to type a file name. if there was a popup keyboard on screen, i wouldn't even have to do that. just to clarify, i do a lot of 2d/3d cad design which i would gouge your eyes out if you made me work without a keyboard, but what MoI seems to be geared for is a less device dependant environment, where your primary interface is either stylus (appears to me as the goal) or mouse alone. I am still diving in to the overall response, but this is what i have found so far.
following with my conclusion the intent is for a stylus/minimalist interface approach, to better attain the "moment" without obstruction of names and extended hierarchy until after the "moment" has developed, i give thought to the PILOU'ian attempt to allow a method of quickly grouping/layering without an extensive compromise on order. no, i'm not sure what to suggest as a solution, i just now have begun the thought. i merely wanted to re-express the direction i understand to be the inceptual intent. PLEASE correct me if this is errant.
is MoI best suited for large assemblies and/or intensive mechanisms, or is it tooled for conceptual yet developable components, or the organic characteristic, or is it to be all and more? the application will drive the implementations. our purpose is to seed the process.
cheers.
384.23 In reply to 384.22
Well, if speed is the case,
why not an auto naming feature that is activated with the object selected and hitting a specific key stroke.
the software will automatically create a group of the selected object(s).
then if you want to, later you can call up a floating window that has the project object list/tree whatever.
Mike Fitz
www.3dartz.com
384.24 In reply to 384.22
Hi MadTooler, you've definitely got the inceptual intent down there.
Initially MoI was created to fill a gap that I perceived in the CAD market, where reliance on the keyboard, right and middle click and the scroll wheel caused existing CAD programs to be frustrating to use with only a tablet. As far as I could tell, there just did not exist any CAD software that worked well in this situation. So that provided an opportunity to do something a little different than anything else out there, which is good because I didn't really want to spend a lot of effort in just trying to make a clone of already existing stuff.
But during the development of a UI to fill that niche, I discovered that removing reliance on those elements also just greatly simplified the UI overall even with a mouse, since less stuff tends to be hidden and things are activated more with just simple left-clicks.
This increased general purpose ease of use, and a focus on fluid ease of use and quick results has kind of become the more dominant intent now. But it is not at odds with the use of the stylus, it encompasses that too.
As time goes on, it will be a goal to add additional power and capabilities to the design tools while still maintaining the fluidity and ease of use. This will happen kind of gradually and carefully in certain areas - object grouping and organization is one of these.
Right now the toolset is more suitable for somewhat less complex models, quick designs, kind of early stage conceptual work. As time goes on I expect for MoI to be more applicable to larger chunks of the design process, although still slanted more towards the earlier stages. This will be an ongoing and slow evolution though.
Does that give you some more of an overview of some of the design philosophy and history?
384.25
So how will this thing be solved....are we going to see usual layres in the next beta or something different...
384.26 In reply to 384.25
Hi Kreten, I don't expect to have anything in this area for V1, it is something that I want to tackle for V2.
The usual CAD layer system has some limitations that I don't like. Like for example since each object goes only on one layer, you can't very easily have organizations like having a car where one wheel is on a layer "wheels", but also the 2 front wheels are on a layer "front half of car", as one example.
I want to have something that isn't limited in that manner. Also I don't really want to have separate systems for both groups and layers, they are performing similar duties so from my view it is bad to have totally different systems for them.
But I haven't had time yet to design a system that accomplishes these things, it will be very time consuming to design a good system for this, so that's why it is not going to be ready for V1, I just don't want to delay V1 for this.
384.27 In reply to 384.24
< and things are activated more with just simple left-clicks.
is not the dreary user of the mac users? :D
384.28 In reply to 384.26
Are you thinking of something like tags and filters?
384.29
I don't care if silo provides some color based nameless grouping behaviour for quick-n-dirty visual grouping.
But having worked on a few moderately complicated models, I can tell you I do want the ability to name/label these groups as the complexity increases. Colorspaces can run out especially quickly before you start getting duplicate colors, or at least colors that look duplicate to the human eye.
384.30 In reply to 384.29
I think that its safe to say that we all agree on the color system as not being the way to go.
I actually think that selecting objects and hitting a keystroke that automatically creates a group and adds this new group to the
project tree wth a default naming system could be a nice way to go.
384.31 In reply to 384.28
Yeah, something a bit along those lines.
I think would be good if you could take whatever was selected, and then add that as an "object set" that will show up in a browser list. An object should be able to belong to multiple sets, which is a lot different than layers - AutoCAD style layers is pretty restrictive in comparison because each object is assigned to only one layer.
Message 384.32 deleted 22 Mar 2007 by JESSE
Show messages:  1  2-21  22-32
