redraw curve to reduce points
 1-10  11-24
3838.11
It would help also if the controlpoints would be located as similar to the control points of the input object as possible. No idea if that would be possible.
Second thing, if I use michaels script I can reduce the points about 3 times, after that there are no changes. Could the script be changes that I could reduce the controllpoints as long as the number of controllpoints from input and output curve match?
nos
3838.12 In reply to 3838.10
Hi Marc,
> Don't know if it has been mentioned before but a slider
> would be a nice functionality in rebuild.
Are you talking about having a slider for the "refit to tolerance" rebuild mode, or the "rebuild by # of sampled points" rebuild mode?
For the refit to tolerance mode, the value used is a distance tolerance value. A slider allows you to pick a range of values between 2 set values at the outside of the range, and for a tolerance value there is not really any good way to pick 2 fixed values for the slider range.
The values you use may be different depending on the scale of the object.
For instance if the slider had a range between 0.01 and 0.5, those would work well for a curve that was about 10 units across. But for a curve that was 1000 units across the entire slider range would be too small in proportion to that object.
It's difficult to have sliders on inputs that use distance values because of the scale-dependent nature of distance values.
3838.13 In reply to 3838.11
Hi nos,
I can't see how that would be possible - the way that rebuild in "fit to tolerance" mode works is that it constructs a new curve that tries to only follow the shape of the existing curve and not pay any attention to things like its current control point structure.
It will put more points in areas where the shape has more local details like when it goes around a tighter bend and things like that.
If you want to have a specific control point count, you need to switch to the "Rebuild by number of sampled points" mode for that - that will allow you to specify a specific number of sample points to use, which will get sampled at evenly spaced increments along the existing curve.
The "refit to tolerance" mode uses an automated fitting process which samples points from the original curve as necessary until the rebuilt curve deviates no more than the given distance tolerance from the original.
The refit to tolerance mode does not necessarily reduce the control point count in all cases, sometimes it may even increase the point count if you are starting with a curve that has a very sparse initial control point structure. But if the curve has a dense control point structure it will usually reduce the point count by quite a bit.
Applying the refit to tolerance mode more than one time on the same curve will not really have much effect because it will give the same results for the same shape.
3838.14
It could be the number of points based on percentage where 100% would be the actual number of points, and 0% the lowest possible.
Or maybe it could work with tolerance values as well, proportional to the scale of the objects.
Like your example it could range from
0.01 and 0.5 on a curve having a length of 10
0.1 and 5 on a curve having a length of 100 and so on.
Marc
3838.15 In reply to 3838.14
Hi Marc,
But there is no limit on the upper number of points - using the Rebuild command does not really have anything to do with the current number of control points in the object. It's sort of similar to drawing a new curve with Draw curve > "Through points" and snapping the newly drawn curve on to the existing one with "on" object snap.
It's not only used for reducing the number of control points in a curve, you can also use it to increase the number of control points in a curve so that you can do more bendy edits.
Here's an example - I started with the rectangle on the left which as you can see has very sparse control points. Then I used Rebuild, # of points mode with 10 points per segment so that I could squish the rectangle around:
Rebuild can be used for more than 1 purpose like this, reducing control point count is not its only function.
I worry a bit about using distance values in this way, it means that you can't be sure to have the same distance value used on 2 different objects.
EDITED: 2 Nov 2010 by MICHAEL GIBSON
3838.16 In reply to 3838.15
Mmmhh.. I see...
I've been doing a lot of photo tracing with Moi lately (so much easier than beziers!) and sometimes a quick way to reduce points would've been nice.
I was thinking it would be great if it could work also on a selection of points.
""""""""""you can't be sure to have the same distance value used on 2 different objects"""""""""""
Maybe it could be an additional option in the command?
Marc
3838.17 In reply to 3838.14
Hi Marc, and here's kind of the opposite example from the last one - here is a curve that has the shape of a simple line:
But when you turn on control points, there are actually 100 control points in that curve, like this:
But rebuild does not care at all that there is 100 control points in that curve initially - rebuild only uses the shape of the curve to guide the newly constructed curve.
Trying to put some kind of special weight on trying to preserve the 100 initial messy non evenly spaced control points doesn't really make any sense here.
That's why it would not really work to try and make Rebuild be connected to the existing number of control points in the curve - that particular information just does not have anything to do with how Rebuild functions (in either mode).
3838.18 In reply to 3838.16
Hi Marc,
That would need something that worked in a completely different way than Rebuild.
That would require something that tried to manipulate the existing control point structure of the curve. That's a lot different than something that just snaps points on to the shape of the curve like Rebuild.
Maybe, but having a lot of interconnected options and overriding things tends to make commands more complex and more difficult to use, so it's not always a good thing.
3838.19 In reply to 3838.17
Yes, It does all make sense as usual.
Maybe there could be another command?
Unmess?
PointTherapy?
LineMassage? :-)
Marc
3838.20 In reply to 3838.19
Hi Marc,
Yeah, I guess since it would work pretty differently it would be a different command.
But the difficult part would be figuring out how it would work. I'm not familiar with any existing NURBS editing techniques that work in that way to reduce control point count just within a selection of existing control points.
Do you have any kind of an example that shows an input and the desired result?
If there are some kind of rules about how the desired result is generated that would then make it possible to implement it, but if the desired result is generated just by using your judgment, that is the kind of thing that is hard for an automated command to replicate.
3838.21 In reply to 3838.13
Hi nos,
>I can't see how that would be possible - the way that rebuild in "fit to tolerance" mode works is that it constructs a new curve that >tries to only follow the shape of the existing curve and not pay any attention to things like its current control point structure.
hi michael
I think my question at the beginning was missleading, cause the basic problem is that the offset function produces a lot of points. So it's probably better to try to have lesser points at the beginning instead reduce them later. Many times I use the offset function I want to tweak the result. In this case it would be ideal if the control point of the offset-curve have a correlation to the source-curve. I don't no if this is possible in any case the offset function is used but it seams that the ofset curve an be generated by modifying the location of the control points.
Here's an example:
~nos
3838.22 In reply to 3838.21
Hi nos,
No, it's not possible to perform an offset just by moving control points around, at least not and make an actual true offset curve that is a constant distance away from the original.
An offset function that only offset control points alone would instead make a curve that sort of generally resembled an offset but would not have the actual "constant distance" relationship.
Your best bet for simplifying the result from Offset is to run Rebuild on it with a tolerance value of something like 0.1 - that should simplify the control point structure of it quite a bit.
But after doing these kinds of various analytic and refitting processes on the curves you won't be maintaining the control point structure of the original curve, these processes work by looking at the geometric shape of the curve (like evaluation points marching along the curve) and not off of its control point structure.
3838.23 In reply to 3838.21
Hi nos, here's a quick example to show you that "control points offset" does not produce an exact offset curve, except in the special case of line segments.
Here I have made a polyline and then produced an offset of it:
Then I drew 2 control point curves (with Draw curve > Freeform > Control points) and snapped on to the end points there, to make these curves:
So you can see there just by eyeballing it that there is not a consistent thickness between the 2 curves.
That's because an offset operation on a line structure is not the same kind of thing as a scaling transformation - applying an offset on just a line structure changes the proportions between the various segments - some segments become longer and some become shorter. Because a line offset produces that kind of changing internal proportions it also follows that just offsetting the control point hull of a curve will also change the internal proportions of the curve.
3838.24
ah, I see, thanks for pointing that out.
~nos
Show messages:  1-10  11-24
