Point from 2 points given distances
 1-15  16-21
Works like a charm! bravo!
A little trick if you dont make a another shortcut and don't want re type the command
Type one time, copy it then just copy past it for the other time ;)
PS
I obtain an error message when I draw first point in Top view, second point in Front view
Seems your script works only in the same window and not with circles not coplanar ?
EDITED: 28 Oct 2010 by PILOU
3832.17 In reply to 3832.16
> the other time ;)
Also if you just want to repeat the last command that was run you can do that by right-clicking in a view port or pushing the Enter key after the command has finished.
Yes, the circles must be coplanar and also intersecting for this command to work properly.
3832.18 In reply to 3832.17
ah yes the right click :)
3832.19 In reply to 3832.15
Works like a charm. Thank you very very much for your effort to make this plug-in.
George
3832.20 In reply to 3832.19
You're welcome George!
Show messages:  1-15  16-21
