curve 2 corner points
All  1  2-3
3831.2 In reply to 3831.1
Not sure there is an easy way
draw a line from the point to change
Add a point near this point to change on the curve
Kill the point
Move the point to the end line
Kill the line
For add a Corner Point
Add Point with Ctrl on the curve near the line extremity
Kill the curve points
Move the corner point to the line
Kill the line
EDITED: 27 Oct 2010 by PILOU
3831.3 In reply to 3831.1
Hi Nos, there isn't a way to change an existing point, so what you do instead is insert a new corner point next to the current one, and then delete the current one.
Or if you want to make a new non-corner point, delete the existing corner point first, and then insert a new non-corner point after that.
In the future I do plan on adding kind of "point properties" option that would let you switch an existing point to different styles.
Show messages: All  1  2-3
