add elements to an object
 1-3  …  24-43  44-63  64-66
3830.64 In reply to 3830.8
I'm having trouble getting the "AssignPresetName" script to work in the release version of MOI 3.0
I've tried all of the suggestion Michael presented.
Here is the error that I encounter.
I keep getting the error about line 58, which is
var env = wsh.Environment( 'PROCESS' );
I've changed line 61 to be the correct MOI 3.0 install path.
I even tried changing line 59, as I have a 64 bit machine which has a "Program Files x86" directory for 32 bit apps.
Is anyone else having problems with this, or perhaps have any suggestions?
Scott
3830.65 In reply to 3830.64
Hi Scott, re: AssignPresetName not working - it's probably due to security mechanisms in newer versions of Windows that prevent programs from accessing some system scripting components by default.
I have just now posted an updated version of the script that should now work ok with v3 and doesn't use that particular method anymore, you can get it from the original post here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3830.8
Please give that _v3 one a try and see if it works ok for you now.
3830.66 In reply to 3830.65
Hi Michael. Yes that worked for me.
Thank you!
Scott
Show messages:  1-3  4-23  24-43  44-63  64-66
