KeepConstructionLine not working in V2
All  1-4  5-7
3811.5 In reply to 3811.4
Hold your hotkey ("K" "Alt+K" or "Ctrl+K") when placing the C-lines.
3811.6 In reply to 3811.5
Oh I see :)
Is there a way to make it work like a toggle ?
So you only press the key once ?
3811.7 In reply to 3811.4
HI DesuDeus - you trigger it after you've placed some clines. It will mark the ones that you have already placed as not being temporary, so those ones will stay around after the current command exits instead of going away when the command ends.
You don't need to press it multiple times, you can just do it once before finishing any command where you have created some construction lines.
Show messages: All  1-4  5-7
