Rotate around selection?
All  1-3  4-7
3805.4 In reply to 3805.3
Hi Burr yeah when you push Reset it will center the view on the selected objects (or on all objects if you do it a second time). So if you rotate immediately after that you will be rotating around the selected objects.
But from what I understood from Nigel's question, I think he's looking for a mode where you rotate around the selected objects all the time, even if you have panned the view off to the side from the initial Reset or something like that. That's a common thing in several polygon modelers.
But it can lead to things like the rotation pivot point being far off to the side of your current view screen.
I think it works better in polygon modelers because it's easier there to select little bits of an object since objects in polygon modelers are made up of all these little fragments, which is kind of different than how NURBS objects are structured.
3805.5
Hi Guys just to add to this, some of the CAD packages I've used including what I'm using now at work have an option to place a view pivot point but never needed to use it, but then again I've always used a Spaceball/Navigator for view navigation, I guess I'd have to use mouse navigation for a while to see if a user pivot point tool would be handy.
3805.6 In reply to 3805.2
Michael.
If I correctly understand what the original poster is asking for, then I think it would be a worthwhile addition to MoI.
As you might remember, I use ViaCAD and believe you might also have it at your disposal. ViaCAD has this feature and I find it's very useful as you can concentrate on rotating around a selected object, point, or groups of objects, that don't even have to be physically joined.
Martin.
3805.7
Thanks for the clarification Michael.
You are correct that this is polygon modeller type behaviour as you often need to tweak points etc to refine your shape and need to spin around your selection to better see what's going on.
Nigel
Homepages: 3dkiwi.co.nz & C4D Cafe
Show messages: All  1-3  4-7
