D-Kfly (Space Fighter WIP) + Align / Orient Question
 1-4  5-24
3796.5 In reply to 3796.2
Oh yeah and like Danny says definitely Copy then Paste is an easier way to just duplicate something in place... :)
But anyway the above should show you how you can use the Orient command to exactly position things as well.
Basically the Orient command combines both moving + rotation together in one command and lets you define the rotation by dragging the axis lines over some reference points.
3796.6 In reply to 3796.5
Hello there,
Thanks Michael for the full illustration, I was actually using the right tool (orient), but I miss the last step.
For some convenience I was detailing a part of the model in a new MoI session, where I did a lot of rotation, so at the end I had to realign the part using some surface I didn't change as reference.
(I should use the CPlane more often :)).
Anyway, thanks for the help !!!
3796.7 In reply to 3796.6
Btw, I'm not sure if it will make any sence, but I'm wondering if a command like this would be possible to have in MoI.
Some sort of inverse blend, well ... I'm not sure about the name :
It will help to create some sort if knife profile
I'm just thinking about it because I have to create this kind of profile a lot in my current project, not sure if it will make sence to poluate the blend option menu with this probably 'strange' function.
EDITED: 3 Dec 2015 by PAQ
Not automatic but maybe useful ;)
3 segments at the start
And kill of course the "third segment" at the end :)
3796.9 In reply to 3796.7
I was experimenting with Paq's inverse suggestion, and was fooling around with using the frame widget to just "Flatten" the blends points, to get his result.. My question is, can the scripting access the points available in this was??
So I used "arc-continue" to create this point structure, and just want to select and flatten the inner points:
This would also work for the blend tool if you didnt want the hard edge for the blade, and required the continuous surface, though using it with blend, you get those "Stacked points" that may not be a good thing...
3796.10 In reply to 3796.9
Well thanks for the suggestions guys,
I didn't think about the arc continue tool to create the shape (to much poly modeling lately), it works pretty well in fact, with or without the flatten point step.
I think I will use this method to sharpen the spaceship surfaces end.
... lovely forum :)
else you can easily inverse the Blend curve (must be half cut up/down)
by two frame box mirror movements ;)
3796.12 In reply to 3796.7
Hi PaQ - re: inverse blend - there is actually such a thing as an inverse blend which you can get by entering in a negative value for the bulge amount.
See here for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3628.47
But it looks like you don't actually want a completely inverted Blend, you want a kind of slightly tweaked in "just a certain way" kind of a blend... :)
Yeah, it's sort of difficult to add in options that are so specific to just one particular project like this - if I did things that way pretty soon there would be a huge list of things under every command and huge lists of things make things more complicated to use.
It's more feasible to make a plug-in to help with this kind of thing instead, since a plug-in does not then complicate the regular UI.
But to make a plug-in, the behavior has to be pretty well specified, in order to automate things there has to be an algorithm or well defined sequence of rules to follow that can then be coded up. Also sometimes I may need to add in additional hooks for scripts to access in order to enable some kinds of things, this could probably be like that.
3796.13 In reply to 3796.9
Hi Burr,
Currently the control points are not accessible to scripting, that's something that I'll have to add in for v3.
But one other thing that is scriptable currently is the bounding box size around the current selection, which includes selected points like that.
I'm talking about this thing here:
When you click on that line you get the size editor that lets you adjust the size of the selected objects, that also works on control points:
That bounding size editor stuff can be scripted, so I think it could be possible to do something like set up a shortcut key that shrinks the selected control points towards the center of the box around them by a certain factor or something like that, it will take some experimentation to set that up, let me know if you would use something like that.
3796.14 In reply to 3796.13
Hi Michael.
I wouldnt need anything cooked up. I would just do the edit frame crunch. Was just looking at Paq's request there, and trying to brainstorm... With the models I've seen him do, I see the "Knife tool" being something he would use a few hundred times per model, so was just pointing out that those "center control points flattened" was what he was looking at... Probably the V3 solution will provide access to make a script that will do the KnifeTool... Anyway, thanks for the response.
3796.15 In reply to 3796.14
Still few surfaces to rebuild/design, but it's mostly there =)
What a mosquito! :)
3796.17 In reply to 3796.16
Some final shot :
Thanks MoI :)
3796.18 In reply to 3796.17
Wicked!
3796.19 In reply to 3796.17
Another cool one PaQ - looks like something that you do not want to have chasing you!
Chikungunya :)
3796.21 In reply to 3796.17
Very cool indeed PaQ !
3796.22
Nice, as always. I hope you've submitted some of your spaceship designs into the eve contest: http://news.deviantart.com/article/128272/
3796.23
Hello,
Thanks for your comments.
The project was indeed for the Eve Online Contest, even if it probably dont fits Eve style :)
The post is lost here -
http://paqwak.deviantart.com/art/Dragon-Knight-Fighter-182418247?q=&qo=
3796.24 In reply to 3796.23
Great Model!
There seems to be a lot of moving parts in this ship!
I like the blue lights under.
Marc
Show messages:  1-4  5-24
