mesh export and normal
All  1-7  8-12
3781.8 In reply to 3781.7
Hi Steve, yup a method for showing which side is the positive normal direction side is on my list of things to add to MoI.
3781.9 In reply to 3781.8
In Messiah, you can display both sides of an object instead of just only the positive normal side.
To do so, I select "render" tab, then "surface" tab, then clic on "defaut" under object name. And then I can see under the surface tab, another surface tab, with "double sided" option.
But instead, I will flip hidden objects, in messiah. It take not so much time and it will render more quickly.
"Display normals" would be a good feature to add to Moi.
Thanks everybody for taking time to help me.
3781.10
Ah good, this is something that I need too :)
Maybe a mode you can turn on where it shows with an arrow or line on each non-solid surface?
3781.11 In reply to 3781.10
Hi NightCabbage,
Yeah either something like that or another possibility is to do it by color, with having the outwards facing stuff drawn in gray but reverse facing stuff drawn in some other color like red. That tends to make the reversed ones a bit easier to see immediately.
3781.12 In reply to 3781.11
< That tends to make the reversed ones a bit easier to see immediately.
Maybe yes :)
Show messages: All  1-7  8-12
