Fillet Problem
All  1-4  5-7
3740.5 In reply to 3740.4
Hi Michael;
Thanks for clarification and explanation. Sometimes I look at the tutorials in other modeling application and try to replicate them in MOI. it is a great way to learn the application. In this case I was watching this video tutorial (http://www.formz.com/webinars/webinars_html/chaise_lounge.html) in Bonzai3d to build the Le Corbusier chaise-lounge furniture in MOI. In bonzai3d with fillet command you can fillet corners in this condition as they were showing in the video. The model was very easy to build in MOI except that I didn't know how to fillet the corners between the arcs and line which with Steve' solution it works perfectly now.
3740.6 In reply to 3740.5
Hi Sharif,
Well, it sort of does but not quite exactly - after watching that video I gave bonzai3d a test to see what it does in that situation (since there is no actual true fillet arc that can work there), and I found out that it creates a blend spline curve in to make that rounded corner.
That could be a potential problem, because it actually says the mode is "circular", yet it builds a kind of generic spline curve piece that is not actually an exact circular arc...
It could be convenient though to have fillet do that, but maybe not in some way that could fool you into thinking you had an arc when you do not, like maybe that could be enabled in MoI if you set the fillet Shape: option to be a blend shape rather than a circular shape.
3740.7 In reply to 3740.6
Hi Michael;
Thanks for clarifying it. I didn't try this problem in bonzai3d, because The trial version of software I had was expired. I watched the video and I thought that was an arc fillet. I totally agree with you and will be nice to have that option in MOI.
-Sharif
Show messages: All  1-4  5-7
