Gears and sine waves and things
3730.1
I thought there would be loads of stuff on how to do what I am attempting but I cant find anything.
How do I chop the top off this cylinder in a manner that leaves a clear sine wave all the way round. I have projected some curves and tried both circular array and rail revolve but I cant get the end points to align. Even if I could achieve this goal it still isn't clear to me how I could chop the top off. I am guessing I could rail revolve a surface to separate the top and bottom of the cylinder.
Any suggestions?
Keith
3730.2
Hi Keith,
Maybe cutting the cylinder at the quadrant of the curve, then Boolean merge and array?
Marc
3730.3 In reply to 3730.1
Hi Keith
As you have the curve projected to that outside surface, separate the tube and delete the inside/top/bottom faces, then use that projected curve to trim off the top of that outside surface, then use shell.
- Steve
EDITED: 21 Aug 2010 by STEVE_HOME
3730.4 In reply to 3730.1
Hi Keith,
Well, if you can get a curve that is projected on to the outer surface of that shape, then you could delete the other surfaces and then trim the outer surface with the curve to slice off the top part, then use Shell on it to thicken that trimmed surface into a solid.
But it may be easier to try and construct a cutting surface.
You mentioned using rail revolve, but instead you may want to use Loft on a radial pattern of lines. For example here I used Transform > Array > Circular to duplicate a line in a radial pattern, then moved some of the lines up and then used Loft (with the closed option checked) to build a surface through them.
Once you have that surface created, you can then use it as the cutting object in Boolean difference to slice your solid into 2 pieces and delete the top part.
3730.5 In reply to 3730.4
Wow thanks
You are a helpful people. I'll give these suggestions a try.
Keith
3730.6 In reply to 3730.5
Hi Keith;
This is another way;
-Draw a circle
-Add a point on the circle and use array circle to copy the points on the circle.
-Copy the circle and points in Z direction.
-Draw wave curve by connecting the points via freeform command (through points).
-extrude the first circle to make cylinder surface.
-use trim to cut the cylinder surface with wave curve.
-use the shell command to give a thickness to surface.
Sharif
Size: 177.8 KB, Downloaded: 118 times, Dimensions: 1920x1040px
3730.7 In reply to 3730.6
Not this picture, but you did say Gears...There's a plugin that will do simple spur gears:
http://kyticka.webzdarma.cz/3d/moi/#SpurGear
