how do I get thickness?
All  1-4  5-9
3714.5 In reply to 3714.3
Your original surface is probably not fully smooth or has broken edges. Can you post the 3dm of the surface and I will take a look.
The easiest way to produce that shape (IMHO) would be to start with a single curve for the cross section,
then extrude,
then shell
then add corner fillets.
3714.6 In reply to 3714.5
Thanks, Steve! Just the outlook I needed!
3714.7 In reply to 3714.6
Yeah Shell for thickening surfaces can get pretty easily confused if you have multiple surfaces joined together unless they are all very smooth to each other where they touch.
The easiest way to guarantee that you've got a smooth piece is to have just 1 single surface.
When there is a sharp corner the offsetting engine does not know how to extend the surfaces so that things meet up properly, but this is an area that is being worked on in the geometry library though.
3714.8 In reply to 3714.7
Yep - I read in the documentation about it. I really LOVE everything about MoI, except that it won't work in Linux. This is not bad at all for a 30 min model - granted, the design is fairly simple:
3714.9 In reply to 3714.8
Hi Phr0stByte, it turned out well!
Yeah one of the focus areas for MoI is to make it possible to produce simple designs really quickly.
Show messages: All  1-4  5-9
