Construction lines not working when using Scale tool
All  1-3  4-6
3692.4 In reply to 3692.1
Hi NightCabbage, also the reason why Scale1D does that projection is so you can match the scale to the height of some surrounding objects easily, like this:
So here the corner of that box is being snapped on to for the final point, but because of the projection that becomes the elevation of that point in the scaling direction.
3692.5 In reply to 3692.4
Thanks Michael
Yeah, I just thought that maybe the construction lines don't have to be resitricted?
"the reason why Scale1D does that projection is so you can match the scale to the height of some surrounding objects easily"
Yes this is good, I like the current behaviour (just not how it prevents you from using C-Lines)
3692.6 In reply to 3692.5
Hi NightCabbage,
Yeah I think that should be possible to set up in v3.
Show messages: All  1-3  4-6
