Hypotrochoid
3668.1
hi all
i have made Hypotrochoid from circle by scaling some control points as in the picture, and is possible to rebuild the circle to add or reduce the control points in paires
3668.2 In reply to 3668.1
Hi Mario, try the Rebuild command. There is not an icon for this command yet, to launch it you either have to type in the command name (push Tab first) or set up a keyboard shortcut.
For some more info see here:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
Yes you can use Moi for some geometric figures :)
Now use the Transform / Array / circular for have the same and variation in 3D Space
And you can use also the new command by Michael: LineWeb for have crazzy wire mesh ;)
http://moi3d.com/forum/messages.php?webtag=MOI&msg=3666.1
EDITED: 12 Jul 2010 by PILOU
