Curve and Points
All  1-4  5-12
3660.5 In reply to 3660.1
Hi Sharif, also you asked:
> 2. What is the best way to create a profile normal to a
> curve at specific point. I use C-plane but sometimes I
> strugle to get the C-plane work properly.
So if you want to draw it directly in place then a cplane would be what you want for that.
Maybe you could try to show me a file where you are having a problem setting the cplane so I could give you some tips on it, but by default when you locate the cplane on a point on a freeform curve it should get aligned to the curve tangent automatically.
Another option is to draw the curve initially on a world plane, and then use the Transform > Orient command to relocate it to a plane normal to the curve tangent.
There are 4 steps to the orient command, you first pick a starting base point, and then the second pick is to adjust the base axis rotation or you will probably just right-click for the second step to accept the current default rotation. Then you do 2 more similar steps for placing the target location. It looks like this (note there are 2 right clicks happening here as well):
3660.6 In reply to 3660.5
Thanks Michael;
the transoform>orient command works very good.
3660.7 In reply to 3660.6
Hi Sharif, I'm glad Transform > Orient will be useful to you.
Also if you place the target point on to a surface it will align to the surface normal as well.
If you want to match 2 solids together you can also pick the base point on a surface from the object you are placing, that will basically connect them together like this:
3660.8 In reply to 3660.7
"Transform > Orient"
Heh, I love this command :D
So useful!
3660.9 In reply to 3660.8
Whoa....I didnt realize the import Point file command had those other "Create a curve out of it" options......VERY COOL!!! and exactly what he was looking for.
3660.10 In reply to 3660.4
Hi Michael;
The second option , save point file, then import point file with control point worked perfectly. this was exactly what I was looking. I also gave a try on "ConnectPoints" script, but it didn't work. no lines showed up between the points. I set the tolerance to 3m which the distance between points.
Thanks again for clear explanation and solution.
Sharif
EDITED: 7 Jul 2010 by SR13765
3660.11 In reply to 3660.10
Hi Sharif,
The method Michael gave is a much better method but, the ConnectPonts script method will work also. The points in the file you posted were measuring at 4.1*** and such, so the value 3 would not produce a result. Try typing 5 and it will do the segments. I then did the join/rebuild and got a curve with no change at "10 points", which is a much less dense curve than the through points curve created with the export point/import point of the original file. If you had many curves like this, it may be good to have this other method available.
3660.12 In reply to 3660.11
Hi BurrMan;
Thanks for clarification. My mistake I had the distance wrong. Yes I tried again and worked fine.
Sharif
Show messages: All  1-4  5-12
