water bottle All  1-4  5-8
3653.5 In reply to 3653.3
Hi tsep,
> i need good geometry... how can i revolve ...?
Check out the "Pod" and "Crown of clubs" video tutorials available here:
http://moi3d.com/2.0/docs/tutorials.htm
Both of those tutorials have a revolve in it as part of the model, so those should help out to show you the steps for creating a base revolve shape in MoI.
But you basically just draw a profile curve, then select it and run the "Revolve" command (it's under the Construct palette on the side pane), and then pick 2 points to define the revolve axis.
All the little raised knob things are going to be quite difficult though. If you already have the pattern of those how you want them in Modo then you may want to export that as an OBJ file from modo, and then use the converter available here:
http://moi3d.com/wiki/Resources#Obj23dmWireframe_converter
which can take the OBJ file and create a 3DM file with the wireframe as lines that can be then loaded into MoI to use for creating surfaces.
3653.6 In reply to 3653.5
thank you, too match... Michael
3653.7 In reply to 3653.5
help me anybody, to make this spiralls.... any tutorial, any examples...
Size: 277.3 KB, Downloaded: 107 times, Dimensions: 753x889px
3653.8 In reply to 3653.7
Hi tsep, the following thread has some techniques that relate http://moi3d.com/forum/index.php?webtag=MOI&msg=3530.1
Show messages: All  1-4  5-8
