Camera matching
 1-15  16-35  36-38
3644.36 In reply to 3644.35
Hi danperk, it turns out that there is a bug in MoI's setting of the FOV angle - the script interface for setting it did something wrong so that the angle that you see or set in the UI does not end up being the proper actual angle in the view.
So you'll need a fix for that before any actual proper matching will be possible. If you e-mail me at moi@moi3d.com I can send you a test version that will help with that.
> Is there a way through scripting to get Moi's current 3D viewport pixel dimensions
> and camera coordinates/focal point coordinates?
Check out here for some script that will get the camera and target coordinates:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5981.2
The pixel dimensions are available as .pixelWidth and .pixelHeight properties on the viewport.
3644.37 In reply to 3644.35
And then when you do get a proper FOV setting, the way the FOV works in MoI is it controls the FOV of the minimum of either the width or height of the view. If the one in Modo is the FOV of the entire viewport width instead then you'll have to take that difference into account as well.
3644.38 In reply to 3644.37
>And then when you do get a proper FOV setting, the way the FOV works in MoI is it controls the FOV of the minimum of either the width or height of the view. If the one in Modo is the FOV of the entire viewport width instead then you'll have to take that difference into account as well.<
Thanks Michael, yeah I got that from your previous posts in this thread. I use the same viewport proportions in modo and it works well.
For anyone who needs it:
script: /* 3D window pixel dims to clipboard */ var px = moi.ui.mainWindow.viewpanel.getViewport('3D'); moi.copyTextToClipboard( 'Height=' + px.pixelHeight.toString() + '\r\Width=' + px.pixelWidth.toString() );
Show messages:  1-15  16-35  36-38
