New Rhino / Cinema 4D Import / Export Plugin announced
All  1-12  13-20
3642.13 In reply to 3642.8
Hi Stefan, just one other note re: adding display meshes into saved 3DM files.
MoI actually has 2 somewhat different meshers that are used for different purposes.
There is a "display mesher" and then there is an "export mesher".
The display mesher's job is to very quickly create meshes to produce the shaded viewport display. Sometimes it takes some shortcuts in order to be fast, and in the future on heavy scenes it will probably automatically make somewhat rougher meshes to reduce memory footprint on detailed models.
When you save to a file format like OBJ or LWO, that uses the "export mesher", which is slower (well not as much anymore with the multi-core processing added in v2, but still) but also does a more careful job and is focused on making a higher quality more evenly proportioned mesh.
You seem to be asking about saving the "display mesh" results in the 3DM file?
The bad part about that is that you would then not be getting the higher quality mesh calculation that is normally done with other mesh exports.
That's on top of the limitations on mesh structure that are imposed by 3DM format.
So it's not really a great solution - there are several reasons why you would not be getting the highest quality mesh results if I just dumped the display mesh into the 3DM file, and then of course there would be a huge increase in the size of the 3DM file as well.
3642.14
In other words, it's a pointless plugin.
3642.15
Is there any update for this plugin so that MOI also works?
Im sorry to ask this, but we are curently planing on going to Cinema4D.
Will workflow MoI for modeling and C4D for rendering work?
Thanx!
3642.16 In reply to 3642.15
Hi Kreten,
Yes - for C4D you can export using OBJ format out of MoI. That's the most common format that is usually supported by nearly every renderer.
C4D's regular built-in OBJ importer works fine, other than one thing which is that it does not import the colors of materials (which in MoI are called styles).
If you want those to come through, get the Riptide plug-in from here and use it for the import into C4D instead of the default OBJ import:
http://skinprops.com/riptide.php
There are quite a lot of people who model in MoI and render in C4D using OBJ format for doing the transfer.
3642.17
Hi Michael!
Seems ok for me.
You said the colors wont export - no problem, but all the material that I have in MoI will also be present in Cinema?
3642.18 In reply to 3642.17
Hi Kreten,
Yeah with the default OBJ importer in C4D, the material _assignments_ themselves (the assignment of each polygon face to a particular material slot) do come through, it's the material properties themselves (which for MoI is just diffuse color) which don't. I can't remember if the actual list of materials comes through or not. But for sure the polygon assignments do.
But like I mentioned above, you can fix this problem as well if you use the RipTide plug-in for the C4D OBJ import, which is available for free from here:
If you use the RipTide OBJ importer everything will come through including the materials list and material colors.
3642.19 In reply to 3642.18
I recently switched to cinema 4D and I bought MoI primary for its superb polygone model export. It is really the best tool I have ever seen since starting with 3D Studio 20 years ago.
You will have much fun with Cinema and MoI!
I am just waiting for MoI in 64 Bit to import LARGER CAD files! ;-)
Best regards
BLADE
3642.20 In reply to 3642.19
blade
i think the same about MOI but i am still curious to hear what you think are MOI's main advantages
over those other programs. in particular i would like your opinion on apple for apple basis (basic modelling features)....
whatever is within your knowledge!
thanks
mario
Show messages: All  1-12  13-20
