grids
363.1
hi, I am new of Moi, compliment to Michael! I would want to know if the possibility exists to create mobile helper's grids...
363.2 In reply to 363.1
There is not but you can easily create one with the "array" grid function :)
As curves has "helpers point inside" that makes the trick :)
Or maybe more simple : launch another session of moi, create your new objet and export it to the first session :)
363.3 In reply to 363.1
Hi Paolino, there currently isn't any way to move the grids around.
I do expect to add this in a future version, but it will be a while before I get a chance to work on this area.
For now you have to build things around the Top/Front/Right grids.
363.4 In reply to 363.2
thanks of the suggestions; another way is that to use a plan as helpers-grid... it is confortable!
363.5 In reply to 363.4
Another thing you may be interested in is that there is an implicit grid movement in elevation built in to many things.
For example, if you start a circle by placing a point in the top view, you can then switch to the front view for the radius point and the circle will be parallel to the front view but go through the first point you picked in the top view.
Many other things behave in a similar way - for example place the first point of a curve in the top view, and then the rest in the front view and they will be on a plane parallel to the front through the first point.
That might be useful to you...
363.6 In reply to 363.5
Yes, indeed this is very useful and it is a great tool because sometimes when I draw something in the front view, I have to move it because I find out that it is away from the rest of the model.
