Top 5 Features list for V3 !
 1-13  …  394-413  414-433  434-442
3628.434 In reply to 3628.433
Hi Ed,
> How is folders inside the browser going? Thats a feature I would really appreciate.
That's not going anywhere at the moment, I've been focused on the new hidden line removal stuff for quite a while.
I definitely want to to have a folder organizer mechanism for the browser but I'm not really sure when it will happen.
3628.435
One feature would be excellent for design workflow, real time temporary cutting plane for working in section. This feature allows people to study their models and add details
3628.436 In reply to 3628.422
I know this is likely to be extremely complicated, but would it be possible to edit a cross sectional curve created in this way and have it affect the original model? I vaguely recall seeing something similar in SolidWorks once, and being impressed..
Also, to add to the debate above, a cross section tool similar to Sketch Up would be very useful for me. It would allow me to expose areas of a model for editing that are otherwise invisible (I'm using Moi for architectural work, so changing floor levels, adding doors, and so on.)
3628.437 In reply to 3628.436
<< a cross section tool similar to Sketch Up
A simple Booelan Diff (or Trim if you want open volumes) by a straight line + hide one part (or move) don't make the same ?
3628.438 In reply to 3628.437
"A simple Booelan Diff (or Trim if you want open volumes) by a straight line + hide one part (or move) don't make the same ?"
It would if I wanted to affect the geometry. It's really a display thing i need, to hide everything on one side of the cut line temporarily.
3628.439 In reply to 3628.438
Make undo after ;)
But Michael will tell you if it's doable or not! )
3628.440 In reply to 3628.436
Hi al,
I guess it's "possible" in the sense that if I buckled down and worked on just that for a year or so maybe it could happen...
It's just fairly tricky finding spare years of work time hanging around though. ;)
There are a lot more basic kinds of editing to tackle first way before that kind of more fancy editing though.
3628.441 In reply to 3628.440
'I guess it's "possible" in the sense that if I buckled down and worked on just that for a year or so maybe it could happen...'
Ah. v4 then?!
3628.442 In reply to 3628.441
Hi al,
> Ah. v4 then?!
It would be fairly tough for v4 as well, since it would be difficult to have a new version that only had just that one new feature in it.
The big problem with undertaking tasks that are hugely time consuming is that it's basically trading that feature for numerous other ones that I could have spent time on instead...
But that's where this discussion thread is helpful - if numerous people started posting here that having that one single feature was the most important thing for them outweighing anything else then that would move it up the priority list.
Show messages:  1-13  …  374-393  394-413  414-433  434-442
