What is the name...
All  1-2  3-7
3619.3 In reply to 3619.2
< The natural way that a surface is moved is by moving the surface's control points around - those are the most basic part of the surface's definition that can be altered directly.
Agree for a surface
so very difficult for a curve as I see :)
3619.4 In reply to 3619.3
Hi Pilou, yes so the problem is that if you draw or project just any arbitrary curve on to a surface, the curve is really a completely separate thing from the surface - that curve does not play any role in actually defining the shape of the surface.
So therefore, editing the curve is just editing the curve and does not automatically or naturally also edit the surface.
It is possible to do some kind of special fitting process that tries to alter the surface to pull it towards the curve, but that would require a lot of specialized calculations, it's not something that is just automatically set up in the way NURBS surfaces are defined.
So it's more speedy to project a line from the top view to the volume (well oriented )
for have an extracted curve from the volume than draw the line on the surface (quasi impossible)
EDITED: 18 Jun 2010 by PILOU
3619.6 In reply to 3619.5
Hi Pilou, sorry maybe I have misunderstood your question completely.
I thought you were talking about projecting a curve onto a surface, then editing the curve and have the surface move with it.
But it seems you are talking about having a curve on a surface, which you can edit and that the curve stays on the surface while you manipulate the curve?
That is something that would be called a "curve on surface". It can be possible to create the curve in the UV space of the surface and then also edit it there, which means that the edited curve stays on the surface.
MoI does not currently have anything set up to make editable UV curves like that though, but maybe in the future at some point.
< But it seems you are talking about having a curve on a surface, which you can edit and that the curve stays on the surface while you manipulate the curve?
Yes exactly (all the curve) :)
Show messages: All  1-2  3-7
