Michael,
You are correct.
I want to be able to machine the cap blank with all the contours, then have the option of machining out various bridge/pickup combinations.
If the neck/tenon area is filled in to match the contours of the cap I can determine later whether to make it a set-neck, bolt-on or thru-neck.
