Finished industrial hall
All  1-3  4-16
3613.4 In reply to 3613.1
Vinced
Very nice image - like it a lot!
To increase the realism it might be useful to alter slightly the textures applied to each of the red objects as it looks as though there are identical paint defects and rust points on each one. This would not occur naturally.
Just a thought(not a criticism)!
Would like to see more models like this.
Mal
3613.5 In reply to 3613.1
Nice job vinced! It's projects like these that get me inspired to look into texturing more deeply, what software did you use to texture and render this.
3613.6
Thanks Nigel and Pilou for the nice comments.
Thanks Mal
"Just a thought(not a criticism)"
no problem. I will change that when i`ve time and post an update. I will use some offset in the textures.
Thank you Danny
I`ve used cinema 4d for texturing and maxwell for rendering. Texturing and lightning is for me always the tricky part.
It`s trial and error until it looks right. The textures i have downloaded mostly from cgtextures and made them tileable. An edited grayscaleimage is used as bump- , displacement- and roughnessmap.
Greetings
vinced
3613.7
As a Maxwell user, I have to say that it is a great rendering...
***Modeler Of Ideas***
3613.8 In reply to 3613.1
Nice work, I like it a lot. How did you make those debris piles?
Armin
3613.9
Thank you very much JTB and Armin
You mean that? (see image below)
At first i did it in MOI, but the pile shape was to round (see first image) so i did the pile shape in cinema 4d again with the landscapeobject(?).
Then it`s just textured with displacement. The displacementmap was done by myself.
Greets
vinced
Size: 45.8 KB, Downloaded: 80 times, Dimensions: 935x469px
Size: 202.9 KB, Downloaded: 107 times, Dimensions: 985x533px
3613.10 In reply to 3613.9
Hi vinced,
Yes, this is the pile I was wondering about. Btw, thanks for sharing.
Looks really good, adds some extra realism.
Armin
3613.11
Hi everyone,
here comes an update which fixes the repeating of some textures and i`ve added some new objects.
I`ve already noticed the hovering sleeve and just started a new render for the next 6 hours :-(
Hope you like the update .
Greetings
Dirk
Size: 342.6 KB, Downloaded: 92 times, Dimensions: 1600x900px
3613.12
I was going to say the same about randomizing the textures on the two pipes - the updated fixed it!
Great work, I like the realism, especially with the debris - it sells the image.
-Will
3613.13
Thanks Will
cheers vinced
3613.14
discovered some days before, that i worked on a badly calibrated monitor.
If my monitor doesn`t play tricks on me this time, then
this is how it should have looked in the first place->
Size: 495 KB, Downloaded: 80 times, Dimensions: 1600x900px
3613.15 In reply to 3613.14
Very nice, looks real!
3613.16
Thanks David!
Show messages: All  1-3  4-16
