Fillet problems when modeling with lofts, sweeps and networks
All  1-7  8-10
3604.8 In reply to 3604.7
Hi sven, even though it's hard to see it unless you zoom in closely, there is just barely enough of a gap between those pieces so that it won't join.
Did you build those piece with the Network command?
There is currently a problem that you can run into with Network - it fits the network surface to a looser tolerance to avoid generating excessively heavy surfaces when making a network through a lot of curves at once.
But sometimes that looser tolerance can result in the shapes being just barely away from the joining tolerance (which is 0.005 units) as well, that seems to be what you have run into here.
That is something that needs to be fixed up in Network, so that the curves on the outermost boundary of the network will get fit to the regular tight tolerance so that they will join more reliably.
Right now one way you can work around that problem is to scale the objects down by 1/10 in size, then do the join, then scale back up again - that's how I made the attached version which has that part joined now. That works because scaling down also scales down the size of the gaps and puts it within the 0.005 unit join tolerance.
Right now the idea with Network is more for building a larger sculptured surface and not so much for making smaller patches like you are doing here.
3604.9 In reply to 3604.8
yeah, its network allright.
Saw Danny's approach on the watch in the end of thesecond thread you send me and that's a very good explanation too.
Lessons learned today. Time to put them into practice, here I go... I was really affraid that I was going to be forced back upon the steep learning curve of Rhino.
No doubt that's a good app, but there is just tooooo much things in it for some one like me, a designer. I just want to create, not study for weeks first.
The scaling tip is allso a life saver.
Thnx!
I'll keep you posted on my progress in the demo and when things work out fine I'll be purchasing, no doubt!
gr.
Sven
3604.10 In reply to 3604.9
Hi Sven, do you maybe have an image or a drawing of what kind of final result you are looking for?
If you could show something like that to me, it could help me to make a more specific example for you.
One of the main things that takes some adjustment for people with a poly modeling background is to rely on cutting or booleans as a main way of working, since for the most part in poly modeling it is something that you try to avoid. But usually with NURBS you want to use cutting/trimming/booleans as a primary way of working.
So there is a pretty different strategy for how to best approach things.
But actually that's why NURBS modeling can be a really useful thing to add to your toolbox, because it has a different set of strengths than poly modeling and it can make mechanical models come together really quickly.
So there is still some learning curve involved with using MoI as well since the overall modeling strategy with NURBS will be different. But I've tried to make MoI's UI more welcoming to artists rather than only being focused on technical engineering users like other CAD programs.
Show messages: All  1-7  8-10
