WIP Railing
 1-5  6-25  26-40
3579.26
Thanks Michael and Brian,
here comes another update.
It`s not finished yet though i don`t know how much i can improve it further.
cheers vinced
Size: 346.6 KB, Downloaded: 65 times, Dimensions: 1280x720px
3579.27 In reply to 3579.26
Great atmosphere and mood to it vinced!
3579.28 In reply to 3579.26
Hi
love the feel of the render. Crying out for something in the doorway. I just put in something I found on google. the doorway is the focal point I think you could do something with it. A person ,a cat, something
regards
Jamie
Size: 366.4 KB, Downloaded: 41 times, Dimensions: 1280x720px
there was a scene like this in the movie Blade Runner ;)
EDITED: 25 Jun 2010 by PILOU
3579.30 In reply to 3579.29
Very impressed Vinced.
I opened up the image a fraction with the PShop Shadow/Highlight filter (as an experiment) and, maybe, you might like to play around with variations to the steel work and floor shaders a bit?
Just experiment. You may still end up as they are!
Brian
Size: 315.8 KB, Downloaded: 40 times, Dimensions: 1280x720px
3579.31 In reply to 3579.30
I played around with some ideas and, really, I think what you have is better anyway!
Still, this may give you some ideas!
Makes the mind work.
Brian
Size: 50.5 KB, Downloaded: 31 times, Dimensions: 640x480px
3579.32 In reply to 3579.31
Just having a bit of fun
Brian
Size: 40.9 KB, Downloaded: 30 times, Dimensions: 640x480px
3579.33
Thank you Michael.
Hi Jamie,
good idea. I will try it with a 2D-Person just black in the entrance.
no, these are some great suggestions. Before i started i had the aim for the first time to use Bodypaint(Cinema4d) to paint the textures, but i totally underestimated the scene size ( i have now 5.x million polys ). The material on the railing is only one tiled material and if i start to paint on it, cinema will create a huge untiled image. To have still a good resolution i might need perhaps 10.000x10.000 or more , i don`t know.
Another way could be to group the railing differently so that i can give every post or pillar a unique material. At the moment one whole level is only one object.
But at first i will only change the easy things, as i am a bit afraid about the work involved if i change the texture of the railing.;-)
you are truly a master. See my reference image below.
En francais je veux dire "chapeau"
cheers
vinced
Size: 65.9 KB, Downloaded: 39 times, Dimensions: 1920x1200px
3579.34 In reply to 3579.32
vinced
It seems so little load on the system to use the shading tree system of Carrara --proceedural shaders?
These are some of the concrete ones in my little experiment.
Brian
Size: 23.6 KB, Downloaded: 31 times, Dimensions: 640x480px
3579.35
that looks cool. These are procedurals? It looked like you have painted them.
Do you know if there is ambient occlusion involved? It seems so, because the dirt is concentrated on the edges.
Unfortunately Maxwell doesn`t have an AO-shader. I will add a dirt and a rust-layer to the railling material and hope it will look good.
It won`t look as good as your materials as the rust &dirt will be placed more or less randomly and not controled by the AO-shader.
The only other way would be to paint the materials. I`ve just tried to make one untiled material for the lower staircase only, but cinema didn`t stop with calcualting the UV`s so i had to abort it after 10 minutes or so.
But thanks for the examples. Your work is really inspiring and rips me out of my lazyness not to do much more with my scene.
cheers
vinced
EDITED: 26 Jun 2010 by PILOU
3579.37 In reply to 3579.35
Hi Vinced
The "dirt" at the edges is caused by an "anything goos" plugin within the shader tree.
I don't understand the term AO-Shader?
I normally do not use any GI rendering and NEVER get involved with UVs.
Attached is an example of the "rusty edges" shader tree set up.
Carrara8 Pro.
Brian
ps I just remembered about the built in AO option in Carrara--which I have only occasionally used.
I tend to render at the default render settings--because they are fast!---then take into Photoshop and, usually, just adjust levels. Much faster.
EDITED: 26 Jun 2010 by BWTR
Size: 158.1 KB, Downloaded: 43 times, Dimensions: 1024x640px
Size: 100.6 KB, Downloaded: 14 times, Dimensions: 360x1160px
3579.38
And another update,
maybe the final one . It`s a bit darker than before.
Don`t get it any better than this.
Size: 276.7 KB, Downloaded: 53 times, Dimensions: 1280x720px
3579.39 In reply to 3579.38
Hi Vinced.
Beautiful work. Love the sense of desolation.
After looking at the picture for a while I thought that, considering the deterioration of the floors and walls, it seemed slightly out of place to have all the railings in perfect condition. I know they are showing rust etc. but I think they might be more realistic if some were bent out of shape, or broken, or missing.
Just my 2 cents worth.
I liked very much your industrial hall image but this is even better, in my opinion.
Cheers and keep posting.
Mal
3579.40
Thanks Mal,
"bent out of shape ect."
I hope that Michael will integrate the deformable nurbs toolset, that is part of the Solids++ Kernel, then i can easily bend them out of shape and integrate some irregularities.
I could do it with cinema also, but for this one i think i won`t do it, because i can`t see that image anymore ;-).
cheers
Dirk
Show messages:  1-5  6-25  26-40
