Till 4 Jun : Octane Render 49€
If you have an Nvidia that maybe a cool render ;)
http://www.refractivesoftware.com/purchase.html
3572.2 In reply to 3572.1
how are rendering times in Octane for an unbiased render compared to Maxwell or cinema internal AR?
How is the material setup working? Do I have to learn new concpets or is it integrated in Cinema already? I only read an announcement that there should be a cinema plugin, but I cannot seem to find it.
What you see is what you believe - so don't. (from an Amiga500 demo)
3572.3
Is there a plugin directly for moi ?
also is there a plugin for modo ?
I have meant to give Octane a try for a while now, hope to get around it sometime soon.
It's a standalone so no plugin needed if you have OBJ or Collada files formats;)
But you have some Plugins inside if you want for some applications :)
Autodesk 3D Studio Max
Autodesk Maya
Autodesk Softimage XSI
Blender
Maxon Cinema 4D, Sketchup and modo are in development and will be available soon.
EDITED: 31 May 2010 by PILOU
3572.5 In reply to 3572.4
Also there will be a Rhino plugin coming in a few weeks. Will only export geometry and camera though. Seems to me it's not much different than using OBJ... Anybody know how this compares to the plugins of other apps mentioned?
jonah
3572.6 In reply to 3572.5
We have developed a standard plug-in specification so that the plug-in will function the same in every application.
Currently, the only benefit of creating a plug-in for MOI3D would be to transfer the camera position (which can be manually entered from MOI3D into Octane.)
The plug-in's really assist in creating animations and re-exporting all the geometry on each frame. I simply just export from MOI3D as OBJ and then import it into Octane. I usually find that I get better camera angles when exploring the scene in Octane than I do in a modeling view port anyway.
Phil
