> would it be possible to have a script to name all objects
> according to their Style name (as a 'one click' solution).
Set up the following script on a keyboard shortcut for that:
script: /* Set object name as style name */ var objs = moi.geometryDatabase.getObjects(); var styles = moi.geometryDatabase.getObjectStyles(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.name = styles.item(obj.styleIndex).name; }> This would really speed up the export process.
I'm curious why you want to do this for your exports?
Object names and style/material names are kind of separate things normally.
thanks a lot.
Well, it is less useful if I am modeling in moi.
However I often get rhino files. In this case, when I just want to export through moi, the names from the layer structure out of rhino are normally sufficient.
