On Snap with Grid priority?...
All  1  2-4
3561.2 In reply to 3561.1
Hi Will, actually in v2 there is already something in place to make Grid snap automatically take precedence over "On" Object snap when both are enabled - it should kick in if you are snapping on to a line that is oriented parallel to one of the grid axis directions.
Here's an example - note how the "On" snaps on this line go in grid increments:
It's not really feasible to do this with just any regular curve though, because it would involve quite a lot of curve/curve intersection calculations.
3561.3 In reply to 3561.1
Hi Will, are you possibly in some kind of particular command that has a special picking mechanism when you were trying it?
3561.4
No Michael, it was exactly as you GIF'd - a simple line that I was adding corner points to.
I think my prob was it wasn't aligned to the grid axis as you mentioned.
I ended up just zooming in real close to add the points...
I had noticed after posting, that at times it did snap to the grid in some cases - I thought I was seeing things though! :-P
-Will
Show messages: All  1  2-4
