trouble filleting
All  1-4  5-7
3556.5 In reply to 3556.1
Hi barney, I've been looking at your problem here, and it appears to be some kind of bug in the fillet surface generation, something like the fillet cross-sections are rotating or wobbling somehow making for a badly shaped fillet.
I rely on the Solids++ geometry library that I license to calculate these fillets for me, so it tends to be a difficult area for me to fix myself, it probably will need to be sent to the authors of the geometry library for them to examine.
3556.6 In reply to 3556.3
Hi barney, so scaling up like Jamie was talking about before does seem to improve the shape a lot in the area that you had highlighted in your screenshot.
Here's what the original looks like in that area when filleted with radius = 0.08:
Here's what that same area looks like when the model is scaled up by a factor of ten and done with a radius = 0.8 :
Still a hint of a problem on the bottom part, but a lot better.
But it definitely looks to me like a fillet surface generation problem in the geometry library, I don't see anything that you have done bad here.
3556.7 In reply to 3556.6
thank you for your advice michael and jamie
now i'm going to crack on and try and make something interesting in moi I can share :)
Show messages: All  1-4  5-7
