How to create this???
All  1-2  3-6
3550.3 In reply to 3550.2
Got it Michael thanks!!
On a seperate note, if I want to offset the edge(curve) of the nose cone along its surface in order to trim with it and create a gap between the cone and the fuselage how would I do that? In other words how do I offset a curve on surface in MOI?
(Trimming with a straight curve in this case is not a good option cause the nose cone has an irregular edge)
3550.4 In reply to 3550.3
Hi niko, if I understand you correctly maybe you could create a tube along the edge you want to offset by drawing a circle and using sweep, then use Construct > Curve > Isect to generate intersection curves between the tube and the surface.
3550.5 In reply to 3550.3
Also for "preserve tangent" mode for the 2-rail sweep to work, the profiles need to not only be on parallel planes, but also have a shared tangent direction between them where they touch at least one of the rails.
So you want to have things like horizontal and vertical curve tangents in the spots the profile pieces touch the rails.
3550.6 In reply to 3550.1
Hi niko, also some tips if you want to use Network for this kind of thing - make sure the curves are actually touching each other exactly at the point, in your curve setup the different endpoints were not exactly touching.
Also if you have pinching in a Network it can often times help if you add a small circle nearby the tip point.
Since a circle has even proportions, it kind of helps to make the tip shaped better, with corresponding more even proportions between the various pieces as they come together.
For example try the attached version (which is the front part of your curves, just trimmed off) doing a Network without the circle near the end (you'll get the same result as you were getting before), and then with the small circle included.
Show messages: All  1-2  3-6
