Untrim
All  1-6  7-15
3545.7 In reply to 3545.6
Frenchy. Be sure to seperate the cube into individual surfaces. I just tried it here and it seems to work. Remember Joined surfaces wont untrim.
3545.8 In reply to 3545.7
<Remember Joined surfaces wont untrim.
Yes that was the trick !
I must separate all before apply the plug :)
3545.9
Remember guys you can still delete openings in a joined surface, by selecting the edge of the opening, but only if it is a single edge.
3545.10 In reply to 3545.9
Aha...So Frenchy was right in a sense. The joined box will untrim if you select and delete single edges....But the script wont work unless the surfaces are seperated...
3545.11 In reply to 3545.10
Well, it could be possible to change the script to work in some different way if someone wanted it to erase all unjoined edges from an object that had other parts that were joined.
It works the way it currently does because from what I understood from Danny's request he wanted something to work on individual surfaces.
3545.12 In reply to 3545.2
I was lucky to find this script
3545.13 In reply to 3545.12
Hi pafurijaz, this old thread was from before there was a scene browser in MoI.
Now this script isn't necessary because you can use the Scene Browser to do the same thing.
If you want to untrim all individual unjoined surfaces, right click on the eye icon on the "Surfaces" entry in the Scene Browser. Now only individual unjoined surfaces will be visible.
Now click on the selection dot on Scene browser > Types > Edges.
That will select all edges of the current visible objects so all edges of the unjoined surfaces will now be selected and you can hit Delete to untrim them all.
Another way you can do it is by using the detailed object properties selection functions.
For this way, select everything then press the "Details..." button to open up the detailed object properties dialog. In the "Type" section of the dialog you'll see a report on the types of the current selection like "3 solids, 6 open surfaces". Click on the "6 open surfaces" label to narrow selection down to those, then click on the edges label to switch selection to the edges of those surfaces and then you can hit delete.
The properties dialog selection narrowing way doesn't need to fiddle with changing visibility.
3545.14 In reply to 3545.13
Or another way to do it in the scene browser without altering visibility - go to the Scene Browser > Types section and do a Ctrl+left click on the selection dot for Types > Surfaces.
That turns on a selection filter for individual surfaces.
Now you can go click on the selection dot for Types > Edges and all edges of only individual surfaces (because of the filter) will be selected and you can now hit Delete to untrim, then hit the Esc key to clear the selection filter.
3545.15 In reply to 3545.14
Thanks you, for this. :)
Show messages: All  1-6  7-15
