beyond me
All  1-6  7-10
3540.7 In reply to 3540.5
Hi Michael
and, yes, I did use 'sweep' and not 'revolve' for that configuration. I'll try 'revolve' next time.
thanks,
eric
3540.8 In reply to 3540.7
Thanks again , Michael ...
It all worked like a charm ...
Thanks again for that quick and thorough response.
I hope I am learning a little as I go along. Mostly I can muddle through.
I am awaiting the documentation for V2 and already wanting to test the V3 betas.
cheers,
eric
3540.9 In reply to 3540.8
Hi eric, no problem!
For v3 I think I have a good idea on what I can to do make a closed sweep like that be slightly better formed at the closure point, which will probably help with filleting.
Is this going to be another piece that you are going to have generated by Shapeways?
Have you done any other ones since your last batch that you posted about?
3540.10 In reply to 3540.9
Hi Michael ...
Yes, I just ordered a couple of these from Shapeways. It is essentially the same one I did before but it is now 2 sided and has a bigger loop for a chain or other support.
I will probably change another one a little bit and may reorder it, too.
I have not done any new ones ... too busy with architectural work ... and planting the spring garden as well as setting up drip irrigation for the greenhouse.
cheers,
eric
Show messages: All  1-6  7-10
