projecting splines
 1-11  12-31  32
3530.32 In reply to 3530.31
Hi NightCabbage,
> But, I guess if the commands are useful, they should
> fit somewhere :)
Yup, the current situation is only temporary. I'm going to try to find a place to fit them.
> Maybe there needs to be a "Line Operations" category, where
> things like trim, extend, and rebuild go?
Well, unfortunately it's not quite so simple as that either - for example the Trim command can trim surfaces or curves, not only curves.
So if it was only found in a "Line Operations" category, that would make it hard for someone to find it who wanted a surface trimming tool.
Similarly at some point in the future I do expect for both Extend and Rebuild to be able to work with surfaces as well and not only curves.
Show messages:  1-11  12-31  32
