V2 beta May-5-2010 available now
All  1-5  6-8
3519.6 In reply to 3519.1
>>Updated the scene remeshing in response to changing of the display mesh settings, to try and catch out of memory issues better.<<
This appears (on the model I posted the crash about) to be now OK when changing the mesh angle (certainly on the quick tests), however, I did forget to drop the mesh angle before loading and although MoI did not crash while loading, the "Styles" did not show once the model had loaded.
I did not check anything else, as I realized what I had done and exit/restarted and loaded model at lower mesh angle.
- Steve
3519.7 In reply to 3519.5
Hi Anis,
> Do you mean that the V2 documentation already done also....
It's not totally done yet but it is getting very close, I only have 3 more topics to fill in for the command reference before that part is done.
3519.8 In reply to 3519.6
Hi steve,
Yeah once you have run out of memory it is likely that all kinds of things will start behaving abnormally, since numerous functions require some amount of memory to be available to them in order to perform their job.
I guess that if a file load caused memory to be all consumed, I could delete everything that had been loaded so far to free up memory. Of course, the net result of that would be that instead of Styles not showing up, there would be nothing from the model at all showing up, so I'm not sure that is any better.
One idea that I have for the future is to try something like only make a rough display mesh with the initial load, and then after the load is complete have some background threads running that would calculate denser display meshes if there was plenty of memory available. Something like this would probably help when working with large models because the file load would complete faster and allow you to work on it as the denser display meshes were getting updated on the fly.
But running out of memory is a pretty tough area to handle well in general.
Show messages: All  1-5  6-8
